DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
S60TEM
Replacing a siemens DVA3 demountable Actuator
S60TEM
Hope someone can help.
This morning we were awakened by a clunking noise coming from our airing cupboard, when I opened the door I found it was coming from the actuator.
Its a SIEMENS DVA3. is there a way it can be fixed or is it just a replacement job?
If its a replacement, whats involved and could I do it or must I get a plumber? Bearing in mind I work with electricity not water LOL.
cheers.
Share this post
Link to post
steptoe
What is it? Is it a motorised valve? You can change the motor part only, its dead easy.
Share this post
Link to post
Doc Hudson
It appears to be a valve that you can replace just the actuator. Siemens DVA3 - H&V Controls, I have no idea of where is the best place, cost wise, to get one from though
---------- Post Auto-Merged at 18:29 ---------- Previous post was made at 18:26 ----------
The actual work involved replacing the part is just normally some sort of lever or clip holding it onto the valve body then just reconnect wire for wire. I am sure you could do it S60TEM, after all, plumbers manage to cope!
Share this post
Link to post
steptoe
Most plumbers merchants should be able to get one i would have thought, or Google! Very easy job.
Share this post
Link to post
kerching
Screwfix universal replacemet motorised valve motor actuator thing, perchance?
Share this post
Link to post
Doc Hudson
Do you have a part number or link for this item Kerching? may help the OP.
Share this post
Link to post
Andy™
heating components
there at gateshead near gateshead stadium. used them a few times for various boiler parts
Share this post
Link to post
kerching
Screwfix 28670 synchronous motor
Share this post
Link to post
S60TEM
Thanks for that mate! Much appreciated as it's exactly the same as whats used in the siemens actuator and the cheapest I could find that on the next was about
Share this post
Link to post
batty
I think they are the ones that just unclip to change over. I have an earlier siemens one on my system but these you cannot change the head so the sytem needs draining down to change it or I could replace the motor as steps has said.
Share this post
Link to post
S60TEM
well i've changed the motor and its still doing the same........damn it!
Looks like i'll have to replace the whole unit! Will I have to drain it all down to do it ?
Share this post
Link to post
Andy™
you will need to drain the system to change the valve.
not really a major job, just make sure you have some spare bits of pipe etc incase you need to alter anything
Share this post
Link to post
S60TEM
well, think i'll get my plumber to come do it for me......don't like messing with water as much as he doesn't like messing with electrickery.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
