Quiz-type question
kme
Fridge Keyholder™
Mar 7, 2008
9,984
In the office again.
I`ve just been asked a question, and I have the answer - as does one other member of the forum.
But I thought, out of interest, and knowing how much searching I had to do to find it......how many others know.
If you`re putting Solar PV on a roof - how close to the edges of the roof can you go with the panels?
Please say where you get your answer from ]:)
KME
300-mm
Its the approximate distance away from the edge where the wind loading on the array significantly drops away. So for those not doing the wind calc this is deemed a safer distance. As you get closer or overhang, building control may get involved.
KOKO
erm.......no!
I was asked this morning; and went through my course notes from the NIC; and checked the powerpoint presentations they use, too - no mention of ANYTHING.
But, I DID find a reference in another book - one of our members had an argument with his boss about this.....I think he won.
The notes I have fron the Logic Certification course just state.
Where practicable the modules should ideally be no closer tham 500mm to the roof edge and if less than 300mm then additional consideration needs to be given to fixing points, wind lift and wind noise as well as rain overshoot beyond the guttering
They also say it must not be within 1 metre of the roof line.
So my guess is they can extend to the edge of the roof.
Okay.
So the thoughts seem to have dried up a bit.
The answer is:
The distance from the edges of the roof should be equal to, or greater than, five times the distance between the plane of the roof; and the array. i.e. however far the panels "stand off", times five.
Next question. If I (and others) have been assessed as "competent" to design & install solar PV to the standard required by MCS.....why isn`t this covered in the course I did? (NICEIC)
well,
on my course we were informed 450mm all round,
but, this doesnt actually seem to be supported in any form of actual documentation anywhere,
so it seems like it was just a rule of thumb judgement by the tutor....
The answer is:
this would actually probably tie in with Catalin's reasoning,
I dunno, :C
The publication I quoted to you this morning does go into such things mate (I`ll get that across to you.........), I suppose they could all have been correct; without knowing what the distance off the roof is............
Ive measure a few different brackets,
the closest I can get to the roof is 50mm with the panel mounted,
the average seems to be 70mm+ , most brackets we have are 60mm to the bottom of the rail, from the tile height, so take 60x5 = 300mm minimum, + rail,
Well I would have said.......
As near to the edge as you can stand without falling off!!!!!!!!!!
But arriving late to class looks like I already missed handing me homework in!
:D :coat
