Not if you make a note of it beforehand, or think to check the manufacturer's website
---------- Post Auto-Merged at 20:11 ---------- Previous post was made at 20:06 ----------
that's what I was thinking. Seems the other guy just made his figures up; which seems odd given how simple the solutions is.
---------- Post Auto-Merged at 20:12 ---------- Previous post was made at 20:11 ----------
Hi One rather rusty Ex GEC Avionics engineer with a question
Voc varies with temperature so it never just one number unless you take the value from the manufacturers specs at 25 degrees. Is that what is used for PV calcs?
How significant is excessively high voc in relation to the inverters max DC rating at say -5 degrees
I stumbled on this thread whilst pondering this question.
I am in the process of getting PV quotes left right and centre to try and get something installed before the FIT deadline
Most reps pump out figures at me using the sap formulas to show how much money I can expect to get back via Fit but as soon as I ask a technical question like this that has been bugging for months they go quiet.
Before getting quotes I played about with the Eversol Everplan tool
and each time I entered say 16x250w panels and picked their TL4000 Inverter all the numbers came up green except one
That being the total Voc at -5 degrees of 1071V which is way higher than the max DC input rating (680V) of the inverter at that low temperature
The tool says reduce the panels on the string but that seems to defeat the object and seeing as just about every installer seems to go for a string of 16-20 panels and a 4KW rating Inverter what is the true risk of anything going bang or being damaged in the colder weather?
what is the presumed minimum temperature to use for such calcs and is the maximum Voc every really likely to be reached?
any educational type links much appreciated
