- Joined
- Nov 28, 2009
- Messages
- 14,666
- Reaction score
- 821
Our main shower has a thermostatic bar mixer that takes mains pressure hot and cold water and mixes it to feed the shower head.
the original one failed (for the second time) so I've just bought another new one.
This new one squeels when you turn it on. Not just a quiet squeel, but an awfully loud, very very irritating high pitched squeel. Not something you want to listen to while showering.
After much fiddling, I have sort of got it under control, by almost shutting off the isolating valve for the cold feed. Now it only squeels when you first turn it on and once the hot water gets through the squeeling stops. but that's still not right.
Although it was bought as new, there's no instructions and I don't even know the make (not that I knew the make of the old one)
Is this common? It sounds to me it doesn't like our relatively high water pressure (about 3 bar)
I'll probably have to send this one back, but what can I do to ensure the next one works okay?
