got one of those Belling range cookers Gas hob and double electric oven. A few months ago, main oven was incinerating everything. Traced fault to temperature controller and thermocouple. thought it odd that the controller just pushed on the back of the oven switch. Not much keeping it in place. A few weeks ago oven started incinerating stuff again. nice batch of bara brith - smelt loverly - burnt to a crisp. assumed the controller faulty again and contacted Espares who immediately sent out a replacement with instructions to send faulty one back.
Anyway pulled stove out this afternoon and pulled the back off. I should add that because its a gas hob there is just a 4" gap between the hob and the oven and the controller is mounted on the front panel so you have to work at arms length holding a torch in your mouth and lacerating your forearms on all the sharp bits of pressed steel in the process. When I took the back off to see, the controller was just sitting there, come off the back of the switch so wasnt seeing the position of the temp knob. what a pain in the ****
DISCLAIMER
I'm sure Belling stoves are excellent but my experience in repairs and maintenance of the aforementioned item was a bad one
DISCLAIMER
