DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Followers 0
jennifersmith
It Is Possible Solar Energy Without Sunshine
11 posts in this topic
All people know that a solar energy system produces usable power from sunshine. But I want to know that does solar only work on warm days. It is possible without the energy of  the sun or not?
Share this post
Link to post
as long as light is hitting the panels then yes
but since your in Oz, you probably only have 2-3 of those dull days per year anyway
Share this post
Link to post
OK, there is anew generation of solar thermodynamic panels for generating hot water, these wotk like air-conditioning in reverse, will work at night, and at temperatures down to -5 C. They work by heat differential, hence don't need sun, but work a lot better if in the sun and during daylight hours, basically beacuse there's lots more free heat available.
Share this post
Link to post
You can get PV to work on a clear night but you need a pretty big parabolic mirror ;)
Share this post
Link to post
or one of these
Share this post
Link to post
:slap
Kinda defeats the point though.
Share this post
Link to post
Unless it is run from someone else's supply!...
Share this post
Link to post
It is not as big as a Suez searchlight.  They could be four feet
in diameter and powered by a carbon arc.
Still impressive though.
Share this post
Link to post
put a hydro generator on the downpipe then
Share this post
Link to post
mine was working today, rain, heavy cloud cover, blowing  a gale. The panels work off infra red anyway, and even on a dull day they will generate, not a lot, but they will still work. The advantage of living in a wet area, is that the rain does help keep the panels clean by washing dust off, plus when the sun does come out, the air is cleaner as it is also free from dust, so the best generation tends to happen after a rainy day
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
