DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
Algor Akl781/wh Cutting Rcd
Hi all,
I am not sure or have not been able to locate the correct answer.
I have an Algor AKL781/WH, it is tripping the RCD only when the oven gets to the temperature. Inherited when we bought the house 6yrs ago so not sure of exact age.
We can then go and flick the RCD switch back on and usually unless we leave the door open a bit too long it will not trip the electric again.
For instance, say we set it to 175 degrees, it will trip, we reset RCD, then it will work ok, unless as mentioned we open door or adjust the oven to a higher temp.
I am not an electrician but know the basics of wiring and always willing to give something a go.
Any help or advise as to what it could be would be greatly appreciated.
Thank you in advance
Dave
Link to comment
ProDave
Yes almost certainly the element.
Trouble is it may test okay when cold.
They are not expensive so get that replaced first and see if it fixes the fault.  Probably cheaper just to replace it than have someone keep on trying to scientifically find the fault.
Link to comment
Andy™
most likely element, possibly fan
Link to comment
could be the stat, as it works again after the RCD is reset
Link to comment
Looking on t'internet, element should be no more than £12 so will get that ordered :)
Will let you know, its worth a shout.
If its not the element, what about the thermostat, since its only cutting when getting to temp?
Link to comment
Andy™
very unlikely to be thermostat. never seen one fail that would trip an RCD
as said above, its either element r fan
Link to comment
Got the element ordered so even if it is not this, then it has not been expensive to rule out.
Even better if it is the element as its been a pretty cheap repair.
Thank you so far :)
Link to comment
Sorry new to this forum, scoob button???
I am a newbie so cant scoob yet looking into it, sorry mate
Link to comment
Andy™
your that desperate you need to change the forum settings to make you look more popular!?
Link to comment
sprocketflup
:slap
Link to comment
Sharpend
Ooooooouchh!!
:slap
Link to comment
Bless `im :slap
Link to comment
Element has arrived today, so took it out and changed it out.
Good news, its all working, appreciate the advice , took it upto175, 200 and then 225 and did not cut out electric.
Thankyou people, really appreciate the advice
Link to comment
ProDave
Thanks for the update and glad the forum was helpful.
Link to comment
Archived
  • Create New...
