DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Triton T90I
revjames
Question
Just been to have a look at this shower...
Property its installed in is very remote and has rainwater tank and a pump/filter.
Accessible by 4x4 or long walk.
Customer switched it on, seemed to be working fine (he did say it made a burning smell after a while) anyway, smoke started coming out and I pulled the switch. I started taking the cover off and the top of the unit caught fire! managed to put it out and remove cover.
The unit seems to be a cross between a power shower and an instantaneous one - 8.5kw.
Connections loose on top of cylinder and wiring burned. I didnt think it was really repairable so recommended replacing it. Big sign inside telling me to stop - before removing unit from the wall call triton.
I wondered if anyone has encountered these showers and if there is a better alternative for a pumped rainwater supply.
Link to comment
5 answers to this question
all triton stuff has that label inside
if its just the connections,  would repair them if practical to do so. triton showers are usually pretty good
Link to comment
I had a poke around and the neutral has broken off so not sure its repairable. Plus it was tripping a 40A breaker so element could be on way out too
and theres a big hole in the case where it caught fire so no IP65 protection now :)
Link to comment
I think it's safe to say it needs replacing now then.
Link to comment
Does it have a hot and cold supply or is it just instantaneous??
Link to comment
just cold supply like a normal shower but there is a motor inside. Water supply to the house is pumped/filtered from a rainwater tank.
Link to comment
Archived
  • Create New...
