DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Downlight Hoods
sprocketflup
Customer has specified Fire hoods for the downlights in his rewire, Ive never bought one but have worked on a few different types.
Does anyone have any recommendations for hoods that aren't to blooming fiddly to install?
Link to comment
Let the customer fit them...that way it will be perfect!
Or.....let customer buy them, then you charge a good extra for fitting them?
Never used them myself so I feel qualified to comment
Just saying
Link to comment
Fire hoods are a bit old hat.... ;)
I'd just get the "can" downlighters with them built in :)
Or... LED (Click Inceptor)
Link to comment
Fire Hoods have been known to almost start fires, they are the devils work.
Safer without if you ask me.
Link to comment
Customer wants, customer gets, that's how they stay customers. This one is spending well with me so id like to keep him happy.
Anyone?
Link to comment
Can you not educate him on the benefits of the self contained or LED downlights?
I fitted some years ago,,,, they're a right pain to get sealed with the cable feeding through them
Link to comment
Noz, you must have had customers like this one, the downlights I'm installing are LED, he still wants hoods. :)
Like I said, hes spending well, I did say he doesn't need them but he wants them anyway.
Link to comment
I tried fitting "hoods " once ..they are the work of Beelzeebub .        I always  fit  fire rated " Cans"  C/w LED  lamps .  Builder is instructed NOT to cover them .
Whoever follows after we're gone ...I have no control over .  Those greater than I should educate idiot lagging compnies about downlights ...but that will never happen .
I wish you the best of luck with the hoods  Sprocket :(     They're about £11 ea  last ones I looked at . :o
Link to comment
Are they in a loft Sprocket ?      Theres a metal cover that fits over the joists for up there , carries the lagging over the top .
Fitting hoods into a floor space is a pain ,   you'll just have to go for it to keep him happy .
I had a customer like him once who insisted on the  board  upgrade being a BS 3036  board , this was about 2 yrs ago ...he was a  Railways engineer of some sort ..... convinced him in the end with a email from wholesaler saying they were unable to source one .
Link to comment
The property is a bungalow, there is 2 layers of Kingspan in the loft everywhere. Ive cut my downlight holes in the plasterboard and have then followed those with a long drill bit to get the centre of the hole in the top layer of kingspan. Ill be using a bigger hole cutter to drill downwards and then installing the hoods.
I cant see it being too much of a prob, but have to find hoods that aren't going to be a total PITA to fit
Link to comment
You can get a 'standoff' that fixes to the top of the can to prevent insulation touching. Think it's on the aurora lights.
Link to comment
Could try these ;)
http://www.homebase.co.uk/en/homebaseuk/flower-pot---15cm-157670
a more serious suggestion :)
https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Downlights_Index/Fire_Cover_Downlight/index.html
from the duck who can't use normal plasterboard to cover holes in a ceiling but has to use fireproof plasterboard coz the surveyor says so! :(
Link to comment
As you're fitting them from above you probably be OK with any  old rubbish .
I'd rather clear a space round them  in the loft TBH ....but the customer wants them so be it .
Just to expand this thread .............more than once I've found downlights drilled & chiseled into floor joists before now .
Link to comment
If you are working from above metal box covers such as http://www.screwfix.com/p/halolite-downlight-insulation-guard-340mm/84802  or  http://www.screwfix.com/p/halolite-downlight-insulation-guard-220mm/97932 are more robust than hoods.
I have used loads of these, good solution
Warning.....wear gloves!....the edges are sharper than a Mother in Law's tongue
Link to comment
Hey what do you know about my MIL?
Just..........Mis reading!
Link to comment
You may be breaching the building regs by cutting holes through the insulation ?
Link to comment
Interesting one that Slips, ran it past the builder today and he didn't think so.
ps. what are you doing on here at 3.40am??
Link to comment
Jeez you're brave monkey, trusting a builder whatever next!
Link to comment
I know round my way they are hot (pardon the pun) on insulation levels when fitting downlights in ceilings below flat roofs.
Link to comment
It pains me when people are willing to compromise the insulation by cutting bloody great holes in it, for the sake of vanity and a particular type of light fitting that was trendy.
IMHO a far far better solution is the modern alternative of flat panel LED light fittings that sit flush and give a very good light without compromising the insulation.
Link to comment
Archived
  • Create New...
