DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
New Member
mark2310
Hi All
Im new to solar panel systems and im in the process of building on for an isolated caravan.
So I guess I will be asking some daft questions fairly soon.
Mark
Link to comment
Hi
Thanks for the info.
I already have 2 panels rated at 235 watts and 37volts each and a controller that works on 12 and 24volts I also have a 12v 110ah battery on the van.
The problem I see is I need to run a 24volt system I think and convert to 240v ac. I know I will need more batteries.
I have a 1000w inverter that is 12v input so this is the problem as I don't think I can connect it into a 24v system.
If I need to buy a 24v inverter in need help deciding which one to get.
How many batteries will I need. I would prefer 12v deep cycle 110ah batteries as these are fairly cheep and easy to obtain.
Mark
Link to comment
The way your question reads, the answer would have to be:  it depends on what it is you intend to run, (how much will the current draw be) as to how many batteries you would need.
Link to comment
Hi
My main concern is weather I can use a 12volt inverter instead of a 24volt one.
I think I need a 24v inverter just need clarification on this first.
The number of batteries may have to build over time to the right amount.
Mark
Link to comment
Archived
  • Create New...
