DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
24V Panel, 12V Batts - Which Solar Charger?
Mark Flint
Question
Mark Flint
My battery bank is 12v but the panels I want are 24v. I'm looking for charge controller that can use these panels and charge my 12v system.
The panels are 24v - max point volt, 33; max open circuit, 46; max amp out, 4; max total power 136w
I want to option of using 4 of these panels for 500w array.
Any suggestions would be appreciated.
Thank,
Mark
Link to comment
18 answers to this question
Mark Flint
I've found a couple of charge controllers that look promising and not expensive, although I'm not sure they sell directly in the UK:
I've cant post links yet, but if you google "morningstar tristar ts mppt 30" or "morningstar sunsaver mppt" you will find them. The first is a 30amp and the second a 15amp, although they also do higher amparage such as 60a units which would be way too big for my boat needs.
Link to comment
Mark Flint
Yes indeed it is
Link to comment
binky
Wire panels in series, ampage will be less than 8 amps unless you buy exotic panels at horrendous prices. Check Ioc - that's the short circuit current flow of the panels you buy.
Link to comment
Mark Flint
I could charge the batteries in series I guess, but I want an even discharge across the batteries. If they were in series how could I evenly draw off power at 12v without discharging one battery before another? Sorry if I ask stupid question, I don't have electrical training.
Link to comment
Richard-the-ninth
Perhaps it would be better if you were to say exactly what it is you are trying to do / run, and why is it you want these 24v panels?
Link to comment
Andy™
surely getting 12v panels to match the 12v system would make more sense...
Link to comment
Mark Flint
I will be running the 12v electrics on my yacht.
I want these panels because they are long and thin (18 foot x 15.5 inches) and flexible - so are perfect for running down the length of my boat.
The panels really are the only 'non-negotiable' item (google Uni-Solar-PVL 136 if you are interested) so I suppose I could possibly run a 24v system on the boat but would prefer 12v.
Link to comment
Sidewinder
There are thousands of 24 to 12 V droppers out there just use one to suit your needs?
Link to comment
Mark Flint
So do you mean use a 24v battery and putting a dropper in after battery? Are they fairly efficient?
Link to comment
Sidewinder
Dropper after the battery or between batteries and panels.
Efficiency you would need to look into yourself and satisfy your own requirements.
Link to comment
Mark Flint
OK Sidewinder, I can see that might be the solution. Cheers.
Link to comment
binky
you don't generally get 12v panels
Link to comment
Richard-the-ninth
Ah, a yacht. Would solar panels really be what you want, or just what you think would be right? I can't help but wonder how good they would be after getting wet on a regular basis. Have you not considered a 12v wind turbine, works when there is no sunshine / light and doesn't need to face any particular direction.
Link to comment
NozSpark
Most yachts now use both solar and wind to charge their batteries.... unless they motor.....
Link to comment
binky
according to a boat sparky I once met, solar works better than the wind turbines, especially if sailing further South, like the Med
Link to comment
Mark Flint
Canoeboy - many thanks for the link, looks good.
Yep, I'm thinking solar first, but also considering a wind turbine as well.
Link to comment
Archived
  • Create New...
