DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Immersion Heater Thermostat Keeps Tripping
SplashDad
I have recently had PV solar panels fitted with Solar iBoost installed to heat my water tank through the immersion heater. My immersion heater thermostat now keeps tripping. Do I need to replace the thermostat for a different type? What tests can I do first?
System is Heatrae Sadia Megaflo
11" 3kW immersion element
Thermostat ref no. 96 612 599
The system works generally for a day but needs resetting every other day, max every 2days but when it's working it works very well
Link to comment
Try turning the thermostat down a bit, may be that switching temp is too close to trip temp.
Link to comment
What do you mean by "My immersion heater thermostat now keeps tripping" thermostats as a rule don't "trip" they switch on and off according to the temperature.
Link to comment
Most now have a safety trip built in that shuts it off if the main thermostat fails.  If the main thermostat is set too close to the (fixed) setting if the safety trip it can cause it to trip.
Link to comment
Thanks guys. I have dropped the temp setting on the thermostat back slightly to see if that helps. Hopefully this will fix the problem. I will update either way in a couple of days.
Richard-the-ninth, there is a small red safety trip which keeps popping. Hopefully dropping the temp will solve the problem.
Link to comment
I have the feeling that it is an indirect cylinder with a boiler also heating the water. In which case the thermostat/immheater should have been wired in series with a motorised valve so that if the set temp is reached (or if the overheat trips) the motorised valve should close, stopping boiler water from further heating the cylinder.
Perhaps the solar pv people installed the wiring directly to the immheater/thermostat and the thermostat is shutting down but the boiler water continues to heat the cylinder. It does seem odd that the tripping occurred after solar pv visit.
Also have you had the cylinder regularly serviced by an unvented cylinder qualified installer?
Edit; as far as I know, the thermal cut-out activates at 95 degrees, the set temp should be around 80 degrees max, why would the boiler water be so hot? Might need looking into.
Link to comment
There will be a separate tank thermostat for the boiler. the immersion heater will have it's own thermostat. I can't believe anyone is that incompetent they would have got the two mixed up.
Link to comment
Archived
  • Create New...
