DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Found On Another Forum
Phoenix
Did he fit MF connectors in the ceiling rose before plastering over it?
Link to comment
I hope there's access from above :o
Link to comment
dont be daft. you need to remove the freshly plastered ceiling if you need to be at the connections...
Link to comment
I've seen this done plenty of times with those horrible stick on polystyrene light surrounds, but never plasterboard
Link to comment
OK matey, own up, what were you doing on the Screwfix forum? lol
Link to comment
looking for you?
Link to comment
OOh. Cruel!
Just as an aside  -is it just me, or is the lamp a bit askew in the fitting?
Link to comment
OOh. Cruel!
It looks a bit wonky.
Just need to change it for a new pendant set.
Oh hold on...........
Link to comment
just cut the flex and feed a new rose with it.;)
Link to comment
As I said on the other forum (a computer based on FWIW)
The correct way to deal with this is to access the rose with a lump hammer, disconnect and fit new pendant set adj. resulting hole and tell the spread he has to come and fix the hole before he gets paid :P
Link to comment
Maybe he's inadvertently hit upon the solution to all those dangerous plastic consumer units?  A bag of multi-finish plaster works out much cheaper than installing a shiny new metal unit..
Link to comment
Needs to be two layers of plasterboard, taped and filled joints, and staggered joints to be considered fire proof.
Link to comment
Isn't 1 layer considered fireproof for 30 minutes?
Link to comment
Yes if correctly installed, joints taped and skimmed with finish plaster.
Link to comment
Thought that's what houses were built too unless build type is non standard.
Link to comment
I have always understood if there's a habitable room above a garage, it has to be 2 layers. That's what we are having to use. Perhaps Scottish building regs are tighter?
Link to comment
2 layers is 60 mins, 1 layer is 30 mins.
Link to comment
And If I remember correctly 90 min is 2 layers BUT with the joists at reduced centres.....i think
Link to comment
Yes Dave you are correct, if habitable above garage then must be double boarded.
Link to comment
Archived
  • Create New...
