DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
Mini Pir Sensor Issue
snacka
Question
hi all im new here so be gentle please
i fitted some 12v led wardrobe lights at home and i connected this to a mini pir 240v in and 240v out this  then goes to the led driver to to turn it to 12v
this all worked fine for the first few days but now it turns  its self on and off when it feels like IE i was in bed last night and the light come  on the wardrobe doors was shut and nothing passed the pir sensor
if i turn it off at the mains then back on it works great for a few hours on and off when it should
but then starts this random pattern
has anyone had any issues like this and can anyone offer advice ??
thanks in advance
Link to comment
10 answers to this question
Andy™
some PIR's have a minimum load
Link to comment
SPECIAL LOCATION
Six immediate thoughts come to mind...
1/ Without any make / model number info this question is about as random as asking... "my computer sometimes does random things has anyone else had any issues like this.....???"
2/ Is it cheap Chinese import stuff that has been installed...
3/ Is the PIR designed to operate the type of load you are working..
4/ Why use 12v LED's?   cut a chunk out of the circuit and use 230v LED's..
5/ Why bother with a PIR at all in a wardrobe ?????
6/ Oh  Welcome to the forumbulator...
:popcorn
Link to comment
it was a cheep chinese import pir an ebay job to be honest
it is designed for led and in the wardrobe because when i open the door i like to see what im doing also having shelf in there the light is mounted to the bottom of the shelf and 12v led because they are safer in can be reached by my  child on the bottom shelf
Link to comment
sounds like there is a problem with that pir sensor its would be best to replace the unit completely.
Link to comment
hi andy dose that mean im not pulling enough power for the pir to work correctly ??
thanks
yer ive alredy orderd one and its on the way but was just seeing if there is another reason that it dose this incase the new one dose the same
thanks
Link to comment
Andy™
possibly. but why bother with a PIR when you could just fit a switch onto the door?
Link to comment
the hole is now cut into the roof of the fitted wardrobe and i thourght it would be a nice touch for the lights to auto come on and off when needed
Link to comment
Andy™
they would switch on / off automatically with a door switch...
Link to comment
Steve3948
I would say load issue, some sensors have issues with 16/28W 2D with random on off, fit a Danlers Capload or similar.
Link to comment
Blue Duck
http://www.argos.co.uk/m/static/Product/partNumber/3400841.htm
:lol:
Link to comment
Archived
  • Create New...
