DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
No Rcd Protection On A Tt Installation
paulcopeman
paulcopeman
How long has it been the normal practise to have RCD protection as standard on all ccts on a txt system because I did a domestic eicr and I was surprised to find the lighting ccts had no.rcd protection. Needless to say a code 1 was the order of the day.
Link to comment
Andy™
slow down...
first of all lack of RCD is NOT code 1 (do you really think there is an immediate danger of someone getting a shock because there is no RCD?). secondly, RCD requirement for lighting is not really that old (17th)...
of course, if you were competent, you would already have known all that
You should go back to your victim and refund them the EICR and tell them to get someone else
and what is a txt system? didnt think my phone txt messages had an option for RCD?
Link to comment
Sidewinder
Never a code 1.
Not even required to have an RCD on a TT under certain circumstances even today by careful design and competent installation an RCD can be omitted from a TT.
However, that does take some doing, I'm not saying otherwise.
It can however, be done.
Link to comment
paulcopeman
The ze is over 300 ohms so no chance of hitting required times for mcbs. Under what circumstances can RCD be omitted on a txt system
I always thought it was always required.
I work in lo.don therefore not worked on tt systems before.
Link to comment
Sidewinder
Look in BS7671 & associated guidance, it's all there, but, a 300 Ohm Ra is not going to cut it, neither is a 200, neither is a 100, neither is a single rod...
Link to comment
paulcopeman
Please don't reply to this post anymore Andy if you have nothing helpful to say.
TO system I meant.
Link to comment
Andy™
id say telling you that no RCD is not a code 1 is helpful... now you know something you didnt before you posted...
Link to comment
paulcopeman
Thanks for that then.
Not a code 1 I admit.
Havn't sent report yet so I'll change that.
Link to comment
steptoe
What is the earthing arrangement.?
I'm confused
Link to comment
sparkyboy1
This is a TT system. Overhead cables and earth rod.
Main switch 60947-3.
First three ccts are lighting. No RCD protection.
Link to comment
Is sparkyboy1 and paulcopeman the same person with two accounts or are they helping each other on this job?
Link to comment
paulcopeman
I am working on my own.
Most days anyway.
Who is sparkyboy1.
Confused.
Link to comment
ProDave
I am working on my own. Most days anyway. Who is sparkyboy1. Confused.
Post #10. He seemed to answer your question as if he knew the install..........
Link to comment
Murdoch
What was the requirement for doing the EICR?
Link to comment
Andy™
:slap
someone forgot which account they were logged in from...
Link to comment
kerching
:slap
I have the same problem...
Never sure whether to use kerching or R?
Link to comment
Murdoch
Its a shame when people ask questions, review input and don't have the decency to respond to questions or points raised.......
Link to comment
Blue Duck
I wonder of the tails have an RCD too?
Link to comment
Archived
  • Create New...
