DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Jointing Sub <0.25Mm Cables
steptoe
Question
so,
any ideas?
I need to joint sub <0.25mm cables, I dont know exact size, but I could measure them if needed,
I did think of gel type crimps,
but, one cable/wire is solid core, one is flexible,
I have tried soldering, but its mind numbing, I have 40+ of these to do at a time.
my other thought was using ferrule crimps with both inserted at once,
no big loads, 3v at very minimal mA ,
any ideas????
Link to comment
13 answers to this question
Have used jelly crimps to join cat5 and beetee stuff with no issues.
What are you jointing? Could some kind of junction box be of use?
Failing that adhesive solder butt crimps?
http://autoelectricalpartsuk.co.uk/products/Terminals_and_Connectors/Terminals_Insulators_and_Connectors/000193.html?gclid=CPeshPamkccCFc7HtAodnmkCmg
better link
http://www.partex-direct.co.uk/SHSB1-White-Heatshrink-Solder-Butt
Link to comment
soldering is the only real option for cables that small, but I would use silver solder paste. It melts at a lower temperature which will spedd things up a little and prevent shrinkage of the insulation
Link to comment
BT style 2b and 3 Gel crimps can be a bit moody if the cable is stranded like alarm cable
Just saying
Link to comment
Link to comment
Why not just crimp the pair into a bootlace ferrule and put a bit of heatshrink over it. You would have the facility still to tap off at that point.
.......................and it's cheap!
Link to comment
Now THAT idea I like :)
Link to comment
Ye, that was a thought,
Looks like that's the way to go then,
I like cheap, :D
It's for connecting some bell wire to an ide cable,
No more breadboard, :)
Link to comment
Steps,
I can post you a bag of twin 0.5mm sq bootlace ferrules if you want them I have loads here, I bought a job lot and the job never came off!
Let me know.
Link to comment
thanks sidewinder,
but they may be a bit large for me,
I've just measured the larger wire,  0.46mm diameter, what would that equate to in mm2 ?
These maybe, or equivalent from CPC. How many are you wanting?
http://uk.rs-online.com/web/p/products/0458689/
I'll just get a bag of 100 I suppose,
I'm at wholesaler on Friday morning, I'll ring them tomorrow and make sure they have some in, its not as if they will be crazy money,
at the minute I'm probably needing 14, and at least another 18 for the next phase, though that may end up being closer to 40 in phase 2,,,
Link to comment
thanks sidewinder,
0.17 mm^2. so working on assumption that your measuring may be out a bit i would gor for 0.2. Same size as as alarm wire ( i think)
Link to comment
thats probably about right, its bigger than telephone cable, its solid core though,
I dug the drum out, but the label has fell off, its been in shed for ever, probably cos its solid core and not stranded,,,,,,,
for the level of power its carrying I dont think crimp size is too critical as long as it fits reasonably,
here we are
http://cpc.farnell.com/pro-power/pet1125/german-single-0-25mm-ferrule-l/dp/CBBR1814
or
http://cpc.farnell.com/pro-power/pet1134/german-singe-0-34mm-ferrule-turq/dp/CBBR1815
Link to comment
Archived
  • Create New...
