Bootlace Crimping Tool?
Mar 9, 2008
2,022
56
Doncaster
Weidmuller, Weidmuller, or Weidmuller.
PZ4 goes 0.5-4mm sq
PZ6 roto is useful depending on where you are criming and goes 0.25(might be 0.18)-6mm sq
PZ16 does 6, 10, 16.
PZ50 does 25, 35 & 50.
That's all I have.
IIRC you can get bigger, you might want to look at the SWA ones, they seem OK.
If you are serious you'll get a "Strippax" & a "Strippax 16" too, they are great when you are doing multicore cables as you set the strip length for the ferrule and they all come out the same length for crimping.
If you are doing 100's then it saves LOADS of grief and hours of time.
They ARE worth the money.
People say Knipex crimpers are OK, I've never had one.
I'm looking for a RYB crimper at the moment, disappointed with the CK one I have.
I don't have enough strength in my hands to crimp 6mm sq 6491 with it now, the old "Cimpstar/Newlec" one I had was fine, but after 20 years it gave up.
ive probably got the same crimpers, yellow is always a little awkward. red & blue works perfectly though
Truth hurts I guess, was hoping for about £50 -60, better save up a bit more then.
I had just clocked the cable craft site and had had a little lok through.
Cheers as always for the replies
My local wholesaler beat any internet price I could find on the PZ6Roto, and the PZ50. (I found out, AFTER I bought it off the internet!)
They do a good crimp.
If you want, I'll send you offcuts of 0.5, 0.75 (If I have any) 1.0, 1.5, 2.5, 4, 6, 10 & 16 with bootlaces on done with the crimpers for you to see.
I don't have any 25mm sq tri in stock at the moment, TBH I will have to check on the 10 & 16, I think I have both.
They are not the same on 6491 type.
PZ4 goes 0.5-4mm sq
That's all I have.
Mine went like that a good squirt with WD40 or equivalent brought them back to life
My Pressmaster PZD3 (4300-2810) does me on bootlaces up to 6.0mm. Wouldn't be without them. Got a couple. About £100 though...............
Ditched the firm supplied RYB crimper years ago as the yellow handle kept slipping off! Favourite is a no name from the boot fair tool stall years back.
my bootlace crimps only go upto 6mm too,
.25 .50 .75 1 1.5 2.5 4 6
unfortunately they miss out .34  , but its not a biggie for me, I cant remember ever having needed it, or loosing sleep about it if I did need it,
I've had them for about 15years, and I dont think they were crazy money when I got them, but, I cant see any name on them, maybe its wore off,  :|
Not sure what mine are to be honest
I think the 16/25/35/50 is a Cembre crimpstar
Smaller one is an RS one .(weidmuller maybe?) but it tends to cut the v small ferules into two bits as it is the type that makes a trapezoidal? Crimp....squashing all 4 sides at once
El,chaepo is an Ampliversal....i think
The ferule squisher on the Knippex Multipliers that come as a set with the Wera driver set is very good as well
Just saying
Just saying
thats a good point?
what is the best pattern to have?
mine makes a row of indents on one side,
Appreciate the offer sidey but I wouldn't worry about it. Thanks
