DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Swa Cable Continuity
micky23english
So when using 2 core steel wired armoured swa cable, what would be the most appropriate method of testing continuity of the cpc to the distribution circuit?
Link to comment
An electrician . . . ?
In some earthing scenarios there may be no direct connection at the far end
Link to comment
I'm training to be a electrician.. and the swa is supplying a detached workshop I'm testing the installation I need to no how you would test continuity of the cocktail to the distribution board?
Cocktail.. #cpc
Link to comment
Why are you testing it?
Link to comment
Same as any other circuit... what diference does cable type make..
john.
Link to comment
Cocktail.. #cpc
Has the training mentioned R1+R2?
But as already mentioned, while it's good to know it tests okay, you very well may not be using the exported earth any way.
Link to comment
assuming the armour is being used as CPC and has been connected correctly, testing is same as normal.
Link to comment
Micky what is your problem with testing it?
Link to comment
Hi thanks for replys I'm actually testing myself the question is based on a design and the question is as follows. The supply to the detached workshop has been installed using two core steel wire armoured cable. Describe the most appropriate method of testing continuity of cocktail to the distribution circuit?
#Not actually testing myself.
#not testing #cpc dam predictive text..
Link to comment
if this is homework, then you would get a much better response trying to answer the question yourself, then someone will tell you where you went wrong. simply asking for the answers isnt going to get you much help, and if you can only pass tests etc being spoon fed then you are not going to be any use when you 'qualify'
Link to comment
Ah we are doing your homework for you.  :innocent
If they are expecting you to answer that, then they will almost certainly taught you one or more methods of testing that. So look back over your course notes for some ideas.
Link to comment
Continuity is continuity is continuity
In its most simplified form it is a measure of the "contiuousness of the core/conductor in question" measured in ohms
Link to comment
No it's not homework it's a assignment it's level 3 a level on design while I have covered some of this on the level 2 what I'm covering now is alot different I have done my level 2 intense over 7 weeks and just started my level 3 the same over 7 weeks while I do appreciate your help I don't want to be bloody spoon fed I'm asking for guidance as I wasn't sure we havnt covered much at all on swa apart from installation of a outside socket using swa on my final exam during level 2. And testing we was shown I don't believe covered continuity. Now forgive me if I'm wrong but this is a electrician forum so don't be surprised when people ask for information!! And thank you kerching I do understand what continuity is I was just wasn't sure how you actually test continuity on this installation if any body could guide me through this it would be much appreciated. Thanks
Link to comment
Look up R1, R2, R1+R2, Wander lead.
Any or all of those will lead you to an answer.
R2 is what you are trying to measure, and it's no different measuring the R2 of a SWA as it is the R2 of any other type of cable.  The value you get will be different to other types of cable, and you have to refer to some tables in the regs book to see if it's good enough or not.
Link to comment
That's great thank you pro Dave really appreciate your help that has help clarify and sum things for me.
Link to comment
hmmm you are suffering from short course syndrome, ie half trained and relieved of much money. Buy the regs if you haven't done so already and get Guidance Notes 1 and 3 or something like this
https://www.tlc-direct.co.uk/Products/BKITCslash3.html?source=adwords&kw=&gclid=Cj0KEQjwmNuuBRDTu5rDjr2kxJsBEiQAWlm6UsqgzDqNd.
you will need to read a lot to compensate for the inadequacies of a short course, and spend a lot of time on here of course. I will advise you to be careful how you post, most of the regulars here are 4 year time served and aren't always patient with short course 'electricians' with good reason, ie they firkin care about our industry and safety of others. Please ask questions before tackling a job you don't understand or feel fully competent to undertake to avoid getting a drumming. Treat the regulars with respect and you will get a lot of help. It is also worth searching previous threads, little new stuff appears on the forum that hasn't been answered previously. As you are learning it is best to pose a question and try to present an answer, as mentioned above we don't like spoon feeding as you seem to appreciate already, but you will get most help when making an effort yourself, including some quite intensive arguments and opinions delving deep into BS7671 and its vagueries...
Link to comment
Thank you for your advice and kind words of wisdom binky I like the way you put it spot on..short course syndrome your not wrong! if I hadn't already invested so much already I would certainly have done things differently i would not advise these courses at all..none the less I'm trying to make the best of it. I don't sit on my arsenal all night I'm doing constant study/revision even finding my own study's etc I'm commited to learning an making the best of a bad situation i just stumbled across this site amongst many I've visited in the last couple months an thought I could gain some help and advice to be honest the college I've used are dreadful so I try to make the most of my spare time gaining as much information else where. Hope I havnt pissed off too many regulars on here an i will use your metheod of asking questions in future. Thank again.
Is that the most recent inspection and testing book binky? So far I have obvs my level 3 book aswell as the regs book and the onsite guide but that book looks handy thank you.
Link to comment
Those are wise words.
It's so common to hear the attitude that I have done a short course so I know it all.   How refreshing to hear you know the limitations and are trying to put things right by learning some more.
Link to comment
as above - being honest with your experience / training will get you a lot further
Link to comment
+3
Be honest and try to answer you own questions and you will get a lot of help where possible.
Link to comment
Thank you for your advice and kind words of wisdom binky I like the way you put it spot on..short course syndrome your not wrong! if I hadn't already invested so much already I would certainly have done things differently i would not advise these courses at all..none the less I'm trying to make the best of it. I don't sit on my arsenal all night I'm doing constant study/revision even finding my own study's etc I'm commited to learning an making the best of a bad situation i just stumbled across this site amongst many I've visited in the last couple months an thought I could gain some help and advice to be honest the college I've used are dreadful so I try to make the most of my spare time gaining as much information else where. Hope I havnt pissed off too many regulars on here an i will use your metheod of asking questions in future. Thank again.Is that the most recent inspection and testing book binky? So far I have obvs my level 3 book aswell as the regs book and the onsite guide but that book looks handy thank you.
I think you will have gained quite a deal of respect with this post
Link to comment
Thank you apologies for taking the wrong approach new to the site all advice taken on-board and learned from my mistakes will certainty be on here for more guidance and would like to say I appreciate your honesty and paitence. Many thanks everyone to be honest had very little experience infact next to none before I completed my level 2 last week which was only 7 weeks ago i started. I was a motor mechanic before so it's a little diffrent I'm now doing my level 3 while I completely understand your views on the intensive course I assure you I'm trying to make the best of the shambles these course offer so i really appreciate your help and advice.
Link to comment
spot on Micky. I myself converted from electro-mechanical engineering via a very short course over 10 years ago, as have quite a few others on here. It isn't easy, the theory is straight forward, it's the hands on that can only be learn't the hard way. I was fortunate to be taught 'house bashing' by an old friend which really got me going. I actually feel I am a better theory electrician than many full time apprenticed types because I spent so much time going out of my way to learn and understand, but still not a patch on many of the regulars on here, particularly in respect to large 3 phase works. I did learn an awful lot from the screwfix forum oddly enough, the viscious personal arguing was quite informative, though completely unnecessary most of the time. Hence the post, I'm quite keen to keep this forum friendly, and have a bit more sympathy to those retraining than some, and don't like to see people get kicked, unless they truly deserve it :^O
so we need a new forum - car mechanics, head honcho Micky
Link to comment
Micky,  ti your advantage, at least you have came from a practical hands on job, so at least you have the manual ability, I would think,
The bigger problems come with some people that have retrained from 'clerical' type positions.
BTW, there are quite a few on here that like to dabble with the internal combustion engine, among other things, even steam engines I would say.
Jeez, Deke computer runs on coal!  :slap. ,,,,,  ;)
Link to comment
Deke has upgraded from Swamp gas then....
Who was the fella with the diesel engine thingy, engine man or something, can't think what the post was titled
Link to comment
Archived
  • Create New...
