Spot The Fault™
i rarely ever use the bit of cheese block that comes with the lights... if youre lucky and the light is wired in bell wire then it might just fit into the terminals if you dont fold it over...
I,hardly ever use the connectors and screws that then manuf. supply......usually,shite.,the exception to the rule on fixings is the plastic plugs that com e with Aico detectors ( strangley not with the radio bases though)....they are really good. Similar to the Uno Plug which I like almost as much as RR,,Wagos,,Clickflow connectors!
