DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Countdown To Christmas!
  • 0
Neff Double Oven 5.7Kw
dave2
Question
Anyone fitted one of these?
Do they come with their own supply cable?
MI's is for 24A fuse rating but no info to enable me to apply diversity.
Had some of these ovens where you can hardly get a 4mm into the connections.
Link to comment
14 answers to this question
Manufacturers part number?
Link to comment
so what is the problem?
2.5 will carry 24A,,,,,,,
Link to comment
kerching
Good luck with the 24A fuse!
Link to comment
I'm still looking for a 32a FCU as requested by MI's :innocent
Link to comment
kerching
I rarely struggle to get cables into terminals
I carry a range of crimps from 2x1.0mm double bootlace ferules , through 25to 16 mm pin crimps , 50mm boot lace ferules right up to 400m lugs
Just stopped struggling years ago
Link to comment
Totally different subject but a lot of the main shower manufacturers recommend installing a 45amp MCB.......has anyone found one of them to date?
Link to comment
MK do one!
Link to comment
Model is Neff U15M52N3GB which customer has not yet ordered.
Steps--- yes I know 2.5mm will be ok for 24A in most conditions but you can't get 24A mcb's, Next one is 32A which would be to big.
So I install 4mm on 32A mcb but MI's state max fuse 24A??????
Link to comment
Hager do 25A MCBs as do Schneider.......
Link to comment
As do most manufacturers
Link to comment
Got to admit  I didn't think Wylex (existing cu) did 25A mcb's but on checking they do.
Thanks for the help.
Link to comment
i think almost all manufacturers do a 25a, just they are not very popular and not normally listed at most places
Link to comment
Archived
  • Create New...
