Neff Double Oven 5.7Kw
dave2
Apr 14, 2008
239
Co.Durham
Anyone fitted one of these?
Do they come with their own supply cable?
MI's is for 24A fuse rating but no info to enable me to apply diversity.
Had some of these ovens where you can hardly get a 4mm into the connections.
so what is the problem?
2.5 will carry 24A,,,,,,,
Totally different subject but a lot of the main shower manufacturers recommend installing a 45amp MCB.......has anyone found one of them to date?
Model is Neff U15M52N3GB which customer has not yet ordered.
Steps--- yes I know 2.5mm will be ok for 24A in most conditions but you can't get 24A mcb's, Next one is 32A which would be to big.
So I install 4mm on 32A mcb but MI's state max fuse 24A??????
Hager do 25A MCBs as do Schneider.......
Got to admit  I didn't think Wylex (existing cu) did 25A mcb's but on checking they do.
Thanks for the help.
