DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Rayburn
Hi there,
I am having problems with my heating and hot water.  They work independently using the programmer but not both together.  Have read lots of posts here about this particular programmer but not found a solution.  I have isolated the programmer from everything else and then tested the voltage outputs and get what I think are unusual results as follows;
Heating only
Brown 67v
Black 240v
Grey 240v
Hot Water only
Brown 240v
Black 67v
Grey 35v
Both together
Brown 240v
Black 67v
Grey 35v
I think that the 240v signals are all as expected and that the other readings ie 67v or 35v indicate a fault with the programmer.  Would be good to know before I simply replace.
many thanks.
Nick
Share this post
Link to post
Blue Duck
Transients?
what did you measure with?
Share this post
Link to post
Rayburn
A standard multimeter across the neutral feed to the programmer and the live outputs from the programmer.
Nick
Share this post
Link to post
ProDave
The fact you get the same readings for hot water only and heating & hot water, suggests you have found your problem surely?
Share this post
Link to post
steptoe
Dodgy 3port,
:C
Share this post
Link to post
NozSpark
could be a 3 port with HW priority......
Share this post
Link to post
monkey5
just for your info there was a recall on these programmers due to this sort of fault, I had it with mine at home, if I set the hot water to come on 10mins before heating all was fine but didn't work if both set to same time, there is a way to find the date code with certain presses (or a sticker on the back), then ring Honeywell, ive had 4 different callout to the same problem in recent years and had 2 replaced under warranty and 2 not so defo worth a try.
hope this helps.
wayne
recalled codes 1037 - 1139
Share this post
Link to post
monkey5
The "Date Code" for this device can be seen on the display if the '+' button is held for about 8 seconds. This is followed by a check sum number. The two numbers will alternate a few times before the display returns to normal
Edited by monkey5
Share this post
Link to post
NozSpark
hope this helps.
wayne
Didn't know that,,, however I have ours set to do HW and CH at different times
Share this post
Link to post
steptoe
Isn't there a switch on the back for gravity HW,?
Share this post
Link to post
Rayburn
Thanks for comments.
ive changed the 3 port and that made no difference. Hence the reason I isolated the programmer before testing any voltages.
It idoes seem that it's a programmer fault.  I will look for a date code tonight.
Again, thank you all for comments 😃
Share this post
Link to post
steptoe
Did it ever work properly,?
The 3 port was maybe not connected right in the first place,, :C
Share this post
Link to post
Doc Hudson
6 hours ago, soundgeek said:
Possible programmer fault. Possible fix here:
Probably already fixed by now as original question was January 2016. 15+ months ago. And the OP last visited 29 Jan 16.
Share this post
Link to post
ProDave
But a useful tip about repairing a programmer. Like everything electronic these days, the old "bad caps" problem lurks again.
Share this post
Link to post
steptoe
but why would you even contemplate spending more than £40 of your time to fix something that isnt worth that much?
attend site, and remove programmer,
go home,
fix programmer,
return to site and re-attach programmer,
thats a lot more of my time than its worth tbh, who would pay for that ?
Share this post
Link to post
Lurch
And as it was only 12 months old I'd have had it replaced anyway, and this is a pretty isolated incident.
Completely not worth the time or hassle for anyone to even bother.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Manufacturers
Electrical & Tool Suppliers
Electrical Software
Green & Renewables
Label Supplies
Accounting Software
Education & Training
Motoring
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
