Roderick Smith
- Feb 15, 2016
- 15
- 0
we are having several issues with thermostats fitted to a hot water immersion tank. I would like help with the first before progressing to the 2nd which is thermostat for the oil burner.
When we switched the electric water heater on recently there was a bang and the fuse tripped out on the main board. We decided to replace the thermostat hoping to get that possible issue out of the way. we purchased and fitted a new thermostat and was pleased it started up straight away. After a few hours tho we had the water coming out scolding hot.
I read about altering the thermostat and turned the dial to here the click, the element stopped but then started again as soon as released the screwdriver. I repeated the turning and clicking to discover it went off completely before noticing it was depressed down and stuck, so could not come up. This kept the element off but as soon as I freed it the element came back on!
so so now tried it again by turning the arrow and pressing slightly which gave the click before releasing and on it came again. I noticed every time I pressed the dial down it clicked off and as soon as releasing it clicked back on. So the removed the thermostat and put back in the old one, lo and behold same issue.
can an someone help please before we go back to the plumb shop? Was the new one faulty? Is this issue a fairly normal one? I will be going into detail on my other thermostat which is oil fired rather than electric and try explain the issues there. currently we just seem to have a constant scolding hot water issue whether from oil fired or electric. I think they are two completely different issues but so annoying coming together. thanks for reading
