Conduit to consumer unit
Deeyewire
Sep 17, 2016
8
A simple question, I suspect. I am running a ring circuit in a shed to a metal consumer unit. The t&e is going through 20mm plastic conduit to the unit, what kind of termination should I use? Is there a gland that takes the conduit into a 20mm knockout in the CU. Thanks.
Yes, (I actually meant radial circuit, not ring!). Can I just use the female adaptor with a metal box? I need to feed the conduit all the way into the 20mm knockout, but wondered whether the standard adaptor and bush was sufficient.
:C
