DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Barx
Commissioning system when using Optimisers
Barx
When fitting a PV system with SolarEdge optimisers, how are you supposed to do the string tests???
Once the string is 'built' the optimisers only kick out 1V per module so no way to take the Voc and Isc readings?
Share this post
Link to post
binky
test the modules before fitting, not that I've done that for years. Modules are more reliable than any other component of the system.
It is more meaningful to look at the output from the system against irradiance / data sheet for module being fitted. You can also look at the screen for the initial start up values, which is more or less the figures you are after. I think you can also 'stall' solaredge by turning of the switch on the bottom of the inverter, which will also give useful numbers.
Share this post
Link to post
Barx
That's all I could think to do @binky...... And hae done ;)
Cheers
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
