DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Followers 0
Tony S
Earth free systems
1 post in this topic
Earth free systems
From experience I can say they are a pain. Our furnaces used DC injection through chokes primarily to detect iron seepage through the refractory. See
Earth monitoring is usually provided as a phase to earth fault could go undetected until a second fault occurs.
The simplest method is using lamps, if one dims it indicates a fault. By using a high impedance Y∆ transformer less leakage occurs, a lamp or relay indicates a fault but doesn’t tell you which phase. A relay could be used as a shutdown system or an alarm.
View full knowledgebase
Share this post
Link to post
Followers 0
