DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
dfc81
Connecting Meter to CSU >3m
7 posts in this topic
I've seen so many different opinions on this but could someone clarify;  what are the rules on connecting a meter to 100A CSU (has dual 30ma RCD's) using 25mm tails and the distance is 4-5m (1m under 1st floor, then 4m in loft of an single storey extension where CSU is located in a small cupboard).
I'm hoping I don't need a 100A Fused Switch on the meter side all the tails from 100A supply fuse are 25mm (double insulated).
Share this post
Link to post
SFU > SWA > CSU
need more info really...
Share this post
Link to post
most DNO will only allow 2-3mtrof tails to be protected by their fuse, so unless you speak to DNO and they allow 4mtr then you will need to install your own overload / fault protection for the wiring
and im sure you are aware that they may also require RCD protection at 30ma. have fun with that one
Share this post
Link to post
@blue duck: why SWA, it's not mandatory if all the wiring is internal i.e. drill hole from loft of the extension -> first floor of attached house
Share this post
Link to post
see line 2 of post 3
Share this post
Link to post
Not 100% sure I agree with that
Share this post
Link to post
may. im not there, i dont know how he's installing it
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
