Building An Electric Kiln For Pottery
Blue Crystal
Mar 22, 2017
2
I intend to build an electric kiln for pottery, clay ( and other materials ) sculptures.
The internal dimensions would be 40cm(height) x 40cm(width) x 40cm(deep).
Therefore, its internal surface is 9600 cm2. I need a maximum temperature of 1300 Celsius.
1) I would like you to confirm or correct this information. I was informed that in a typical kiln the calculation of the total Electric Power necessary is given by this formula P ( Watts ) = 0.6 X Total Internal Area ( cm2). If that is true, then I would need 5760 Watts. However, I found in the internet values that are different from 0.6. So, if you are an expert please give me your informed opinion on that.
2) In order the temperature inside de kiln could be as much homogeneous as possible, its internal walls should be filled with as much heating element wires as possible. But there is a trade-off to be made. The more heating wires the bigger will be the resistance and the weaker will be the production of heat.Furthermore it may unnecessarily increase the cost of heating elements. Additionally, there will be the need to carve too many grooves on the refractory bricks to fit the elements inside which will weaken and possibly fracture them. By looking at the pictures of many different kilns it seems that the optimum distance between two parallel coiled wires is about 7cm ( axis to axis ). But if the grooves should be carved directly on the bricks and in the middle of their height then the distance between parallel grooves would be equal to their height or a multiple number of it.
Would you agree with my reasoning or do you have a different one ?
3) It seems to me that 3 resistors ( heating elements ) electrically connected in parallel is a good circuit because they would use only three relays and probably could be controlled by an electronic controller. What is you informed opinion on that ?
4) Another important aspect of the kiln design is the coiled wire ( heating element ) diameter. The bigger its diameter the bigger will be its durability. However bigger diameter reduces the resistance of the heating element and produces lesser heat. I intuitively think that a diameter of 1.30 mm would be OK. ( Of course, later on, I should also consider the coil diameter and the distance between its turns ).
Do you have a better informed proposition ?
( later on I may need further advice on the same project )
I supplied power for one in a fancy shed.
They had a kiln specialist come over and connect the Kiln controller and kiln.
I did ask, i might have remembered this wrong. The kiln controller heats it gradually over a set time time as going straight to full power would affect the medium.
They had some in the hospital. They definitely sloped up and down. You could tell the thing how many hours to spend heating up, how long to hold the temperature, and how many hours to take cooling down..
john..
