DRW
Gas Emergency Stop buttons - wiring??
DRW
I need to re-site an existing push stop button which is fine as it is moving closer to its source but I also need to fit an additional button.
There is an extraction monitor unit box that allows/prevents gas flow that is close to where the new stop button will be located so i want to take the feed from there but could anybody point me in the correct direction where to find the correct wiring info please....I am a sparky but have never done these before and would like to go in armed rather than thinking on my feet completely.
Ta
Dave
Share this post
Link to post
DRW
I have some work to do on a commercial kitchen that has Emergency Stop buttons for the gas supply. I need to re-site an existing push stop button which is fine as it is moving closer to its source but I also need to fit an additional button.
Ta
Dave
Share this post
Link to post
Evans Electric
Those buttons are usually wired in series DRW , you could series it up in the panel . It could be an NC circuit also.    Try googling the panel though , you may find the Manufacturer's instructions .
A word to the wise ......  do not try guessing how its wired , it has to be right .
I take it that , naturally, there are no As Fitted drawings on the site?
Edited by Evans Electric
Share this post
Link to post
DRW
Hahaha - no there aren't. Tbh I'm not sure if google will know the answer on the main panel - it's possibly as old as me, but i will look.
Share this post
Link to post
Evans Electric
Well as long as it  is'nt as old as me you may strike lucky .
Share this post
Link to post
DRW
hehe.
Heavy duty pvc conduit is ok I'm assuming. The existing is all in Steel. I'll take the cable size needed as the same as installed.
Share this post
Link to post
Andy™
if the existing is in steel its probably in steel for a reason and PVC may not be suitable
Share this post
Link to post
Evans Electric
Possibly the effect of heat in a commercial kitchen on PVC conduit would have it drooping all over the place.
I'm trying to remember ...the gas shut-offs I've done  were a low voltage , DC  solenoid valve at the input with , as you say , a control panel , emergency stops, and sometimes a steel wire with soldered links at certain places,  the wire holds up a weighted handle on the gas valve , if solder melts , the handle drops .
Share this post
Link to post
ruston
Yes , there will be a gas interlock system connected to the extractors . You will need to know the system . Temp shut off built into the controller .
 They are not all straight forward.
Share this post
Link to post
Evans Electric
Yes they are as Ruston says , you need to take care .      Just remembered the last one we did was to fit a test key to the fire alarm ( which also knocked the gas out) .  Wire a key in so that the weekly test didn't shut the gas off but a full fire alarm would.
Share this post
Link to post
Richard-the-ninth
As its an additional button, could you not look at the existing button and see what that connects to?
Share this post
Link to post
Sidewinder
Topics merged as they are the same Q by the same poster.
Share this post
Link to post
DRW
Yep, I think it's all good. A 10min mooch today revealed which connection in the main control panel is affected so I can just series connect the addition in line a Robert should be my fathers brother!
thanks for the pointers
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
