Abit confused, need help with sunbed
vad25
Jul 6, 2009
60
Hello every one.
I hope somebody can help me, so as I'm a bit confused about technical data received from client to provide new circuit for sunbed.
 It is made in America and 3ph but 230 volts and I can't see Neutral incoming.
Also some instruction from contractor guides:
This unit requires a 230 volts, three phase, 80 amp (4 wire) circuit
actual amp draw of 58 amps
This unit has approximately 5 ft. of # 4 AWG wire (3 hots, 1
ground) coming out of the left side of the back panel
Will be it correct if I install 63 Amp MCB and rotary isolator with same rating or it must be 80 Amp.
Thank you
This is NOT suitable for the UK, wrong voltage. Tell the client to send it back and buy one that is rated for the UK  I will bet it does not have a CE mark
Even if it was, at 21KVA you would not get me under it, you would be burnt to a crisp in no time.
Following to your advice I'm already inform client and she agreed.
Thank you to all of you for reply.
After client contacted with sunbed supplier it been confirmed that it is 400 volts 50 amps. and my job is just provide circuit and isolator.
Thank you again
Thank you again
Is it CE marked, or are the supplier and the user both willing to break the law of the land?
