jack2017
Related to my pond pump thread but I thought this may be simpler - hope thats ok
I have a single 13A socket with a spur taken off it.
Ideally I would like to add a second spur to feed my pond pump.
question is - what is my allowed method of doing this as I'm looking for
the simplest implementation?
Looking at the 433.1 reference jpg posted in another thread I'm not sure but can I
1. Blank off the socket and feed 2 spurs from 16 or 30A chocolate block from inside
the box. (the feed would not be fused in the socket box then although it is on RCD)
2. Install a double switched socket and take the second spur off the second socket
3. is there something else I could or must do
I just want to get this done as quickly and simply as possible.
If you didnt read my pond thread the spur I'm feeding to is 1.5mm SWA cable to
a pond pump.
thanks
jack
a pond pump.
thanks
jack
