DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Rana Abbas
10 mm single wears how much ampere
11 posts in this topic
10mm wears how much amper
Share this post
Link to post
you better explain as I've no idea what the question is!
Share this post
Link to post
its how many of these Amper jackets can be worn by a bit of 10mm. id say 3
 http://www.skis.com/Karbon-Amper-Womens-Insulated-Ski-Jacket/463570P,default,pd.html
Share this post
Link to post
Your question is extremely vague. There is different types of cable and different ways it can be installed. There is a list of tables on the link below.
https://www.cse-distributors.co.uk/cable/technical-tables-useful-info/
Share this post
Link to post
What regulations / codes does your country use? All IEC and NEC countries have current carrying capacity tables in the published regulations / codes.
Share this post
Link to post
 Iz ≥ In ≥ Ib
simples
Share this post
Link to post
ID: 7   Posted (edited)
Is there any need to be funny or awkward???? It is completely obvious what Rana means.... can any of you explain technical questions in a foreign language?? No, thought not.....
Hi Rana,
It all depends on the type of cable and where it is installed. You see, not all cables have the same type of insulation on them. some can stand higher temperatures than others, so we would need to know exactly what cable it was.
Secondly, it all depends on where the cable is installed. You will understand that a cable installed in a hot place and covered in thick insulation will not be able to safely carry as much current as a cable outside in fresh air clipped to a nice cool brick wall..
john..
Edited by apprentice87
Share this post
Link to post
If he falls under NFPA-NEC codes the answer will be totally different to BS7671
Share this post
Link to post
To be fair, I think he's gone never to return
Share this post
Link to post
probably not. joined, posted, then never returned
Share this post
Link to post
42
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
