DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Niyi
Mr
10 posts in this topic
Am Niyi, a Installer of CCTV, burglary alarm, fire alarm systems and am here to gain more knowledge on my field.
Plz can someone help in practical step in wiring panic button in series.
Share this post
Link to post
It's easy, if say you use the blue core and the yellow core as the panic button circuit, then you connect yellow and blue to tamper terminals in the panel and at the button end to the switch terminals, if you want to add another then link remove the yellow from the terminal and connect to yellow on the cable to other panic button. Connect blue to the terminal where you removed the yellow wire from and at other end of cable connect panic button the same as you wired the other button. You can do the connection for the second one at either the first panic button or at the panel depending on which is easier.
Share this post
Link to post
Yes, but is just two cable use(red & black) the panic button is not connected to tamper but connected to zone 6 of the panel.
Share this post
Link to post
Ah well, you're screwed then, it only works with yellow and blue.
Share this post
Link to post
You can use any colours you want, I just said blue and yellow as they are the colours that I use, it's not rocket science.
Share this post
Link to post
But is that pre or post harmonisation? Probably needs to be grey and black now for it to work.
Share this post
Link to post
I use orange and pink,
I think it depends on the panel spec, or maybe the switch, as the one in my garage/shed/workshop/spare room only seems to work using white and purple, :C
Share this post
Link to post
Thank you all
Share this post
Link to post
hopefully its not EOL...
Share this post
Link to post
No
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
