DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Andy™
hotpoint washer
Andy™    2,096
Andy™
ive got a dead hotpoint WML560 washer. when its switched on it on door locks & fills with water as normal then nothing. no spin. usual LEDs are on (power, door locked and where in the program it is). seems to be either the PCB not powering the motor or the motor not working.  if you leave it for a while it does not progress further into the program so probably the PCB
anyone know how the motor works? there is a 7 way connector (exc earth) with 5 black and 2 red (which are for the speed i think). one of the blacks is live but nothing else
Edited by Andy™
Share this post
Link to post
Andy™    2,096
Andy™
edit: pin 2 of the blacks is live at 230v. 1 3 4 & 5 have between 20 & 40v (all with reference to neutral)
Share this post
Link to post
Andy™    2,096
Andy™
edit 2: found it fault, brush not fully making contact... should have ripped the motor out first
Share this post
Link to post
Sharpend    639
Sharpend
It is usually the brushes worn if everything else is working as per it should.
You can pick up the brushes for a few quid, quick change and all is good again. :)
Share this post
Link to post
Andy™    2,096
Andy™
already ordered some, it was just the fact that it didnt go further through the program that made me think it was the PCB. that and the motor has a tacho so would have expected some kind of error when it didnt detect motor spinning when it should have been
Share this post
Link to post
Blue Duck    560
Blue Duck
I'd have chucked it out before it spontaneously  combusted!
 baddayexplode
:slap
Share this post
Link to post
Andy™    2,096
Andy™
its in a metal case. its fine
Share this post
Link to post
phil d    211
phil d
I used to work on industrial laundrette equipment, an interesting thing about the brushes going, is you do get a warning, before they fail completely they don't spin as fast, resulting in clothes coming out damp.
When a programme doesn't advance it's quite often one of two things, either the pulse motor on the programmer is knacked, or the line to the pressure switch is blocked, it uses the pressure switch to sense there is the right amount of water in the drum before it advances the programme.
top tip with washing machines, if the rubber door seal is not kept clean inside it can develop a hole, sooner rather than later, if this happens then simply release it and rotate it 180 degrees, the hole is now at the top, it won't leak water, and you can keep the wife happy until you can get a new one.
Share this post
Link to post
Lurch    520
Lurch
Not seen one of those for an few years!
Share this post
Link to post
Sidewinder    1,942
Sidewinder
I got called out to work on a washing machine a couple of weeks ago!
Share this post
Link to post
Sharpend    639
Sharpend
Ok so I know the industrial look is all the rage in modern houses but that's taking it a bit too far!
Share this post
Link to post
phil d    211
phil d
Hospital perhaps?, worked on some dishwashers that size a few years back.
Share this post
Link to post
Sidewinder    1,942
Sidewinder
Well central hospital laundry for about 8 hospitals.
Share this post
Link to post
Andy™    2,096
Andy™
at least you have a manual for it
Share this post
Link to post
Sidewinder    1,942
Sidewinder
Hmm, manual is a mute point.
It's not very good, and there is a lot of information missing, it doesn't comply with the requirements for a manual under the Supply of Machinery Safety Regulations by a long shot.
Share this post
Link to post
Marvo    218
Marvo
Glad it was just brushes, at least it's a cheap fix. Most of the newer domestic machines are inverter driven motors nowadays and not so easy to fix.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
