CK-TOOLS 19 Report post Posted August 14, 2017 Hi all, We're looking for some feedback on how we can improve your working life! Please take part in our poll and share your input! 0 Share this post Link to post Share on other sites
Lurch 510 Report post Posted August 14, 2017 Can you make a hook that only hooks 1.5mm² green/yellow singles? I am constantly cleaning up piles of insulation that I keep pulling out of random holes! I notice in your video for the new rods that it was all over ceilings and under floors, nice easy stuff. I can do that with any old bit of trunking lid/old curtain track/snapped off branch (not belittling the rods though). The more challenging job is fishing blind between 2 rooms through a 10-20mm hole each end through brick cavities between floors stuffed with insulation. Now if you could make something that enabled me to do that first time, or even in the first 10 mins, I'd be all over it. Many a time I have spent an hour or more fishing wires to save having cables on show, customers love the end result, I don't enjoy the journey! 1 Share this post Link to post Share on other sites
ProDave 2,113 Report post Posted August 14, 2017 I use a steel fish wire that rolls up on a drum. It has the big advantage over "rods" that you can pre bend it to any shape you want to fish things round corners or through holes that are not in line with each other. 0 Share this post Link to post Share on other sites
Andy™ 2,584 Report post Posted August 14, 2017 i often use 2.4mm welding rod bent to whatever shape necessary 0 Share this post Link to post Share on other sites
Sharpend 1,120 Report post Posted August 14, 2017 I just smash a big enough hole to see what I'm doing! 0 Share this post Link to post Share on other sites
PPP 12 Report post Posted August 15, 2017 I've often thought a passive proximity tag on the cable / rod in the wall and a detector in your hand would save a lot of "why isn't the cable where I think it is" moments. cheers, Paul 0 Share this post Link to post Share on other sites
Onoff 869 Report post Posted August 15, 2017 I've stolen a few of the kid's Geomag magnets, taped to the ends, the two "meeting" rods don't need to be that close for them to find each other they're so strong. Similarly used on a line before dropping down between studs. You also hear a quite loud "click" as they come together. 0 Share this post Link to post Share on other sites
Lurch 510 Report post Posted August 15, 2017 13 hours ago, Sharpend said: I just smash a big enough hole to see what I'm doing! There was a bloke we used to call 'Head & Shoulders' because he'd start with a little hole just big enough to get the rod in and then he'd keep opening it up a little bit more until it was more 'loft hatch' than 'access hole'. 3 Share this post Link to post Share on other sites
kerching 2,404 Report post Posted August 15, 2017 12 hours ago, Onoff said: I've stolen a few of the kid's Geomag magnets, taped to the ends, the two "meeting" rods don't need to be that close for them to find each other they're so strong. Similarly used on a line before dropping down between studs. You also hear a quite loud "click" as they come together. Agreed I use the Super Rod sets.....the double magnet OR the magnet and chain set have got me out of the poo on a number of occasions 8 hours ago, Lurch said: There was a bloke we used to call 'Head & Shoulders' because he'd start with a little hole just big enough to get the rod in and then he'd keep opening it up a little bit more until it was more 'loft hatch' than 'access hole'. We had a bloke worked for us...his nickname was Canestan ...he was an irritating. ???? We had another called 'Rockwool' as he got up everyone's nose 1 Share this post Link to post Share on other sites
Andy™ 2,584 Report post Posted August 15, 2017 im glad i work mostly on my own 1 Share this post Link to post Share on other sites
kerching 2,404 Report post Posted August 15, 2017 I work 99% on my own now. Apparently the above two statements can be applied to me at times! i know, I know it is hard t believe but nonetheless true 0 Share this post Link to post Share on other sites
