DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
yiwai
How to improve RTC timing accuracy (error no more than 0.5 s/day)
yiwai    0
yiwai
As shown in the attached picture, about the RTC chip,I adopted DS1302, which is directly inserted, and the load capacitance is 6pf, C47 C52 was not welded.
forum.php?mod=attachment&aid=OTA0NDY0fDM
With 20ppm, the error is 2s/day. And then I tried again with 5ppm, the error had not changed.
Is there any better way to improve the accuracy?
Share this post
Link to post
Sidewinder    1,959
Sidewinder
Hello, yiwai, welcome to the forum, we are mainly focussed on UK building electrical installations, though a few of us have some interest, and some work outside that field.
When you say ppm, I read that as parts per million, is that what you mean, and if so with regard to what?
If not parts per million, what are you using ppm to refer to?
Share this post
Link to post
kerching    1,875
kerching
Pulses Per Minute?....probably not
just guessing
Share this post
Link to post
Tony S    354
Tony S
RTC = real time clock.
It’s a long time since I’ve dealt with Op Amps and to be frank I’m not quite sure what you’re asking.
PLC’s use RTC for data logging, is this what you want?
Share this post
Link to post
phil d    219
phil d
If I remember correctly altering the frequency will alter the accuracy, but I cant remember how to work it out, I,m referring to item marked as Y2. hope this helps.
Share this post
Link to post
Doc Hudson    1,034
Doc Hudson
I would assume you have looked at the DS1302 data sheet links for clock accuracy which refer to application note 58?
https://www.maximintegrated.com/en/app-notes/index.mvp/id/58
Other than that you are probably better looking on an electronics based forum rather than an electricians forum aimed at UK electrical wiring practices and regulations.
Doc H
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
