DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
istranghero3000
Sunny Boy 1200
istranghero3000
I just have this inverter sunnyboy 1200 from SMA. but I want to change some parameters about "frequency" it was set to 50Hz, then i would like to change to 60Hz. because i would like to
bring it to Philippines and use it there. Is there anyone can help me or need an input to change this parameters is very much appreciated.
appreciated.
Thanks.
Share this post
Link to post
binky
Best contact SMA technical help for that.
You will need to download software and get an access code to re-set parameters like frequency. I'm not sure SMA will give you the access code if you are un-qualified.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
