DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
Evans Electric
ADE Optima / Accenta
Evans Electric
Customer phoned today ,  its one  we fitted in 2004 ,   says the two alternating LEDs  in the  sounder box  have gone dim .
Anyone know if its  fault  or are they worn out .  ?
Not fitted these for years , changed to Texecom .
Share this post
Link to post
Lurch
What bell, panel info is irrelevant. The LEDs flash with just 12V applied, nothing to do with the panel. Having said that though, doesn't really matter anyway. Some do go dim, either with things wearing out or with the box ending up full of crud. When was it last serviced? Probably time for a new bell anyway, doubt the batteries in it are any good now.
Share this post
Link to post
Richard-the-ninth
LED's do not wear out, it may be the SAB battery is drawing more current than it used to, so the voltage to the LED's is less. It could also be general dirt and grime on the box / LED's
You could clean it, or change the whole box.
Its your choice what you do next. I doubt you will change the box FOC, but then to look at it will take time too.
Flashing LED's on bell boxes t me are a complete waste of time as they often cause problems like this.
Another thought, if the panel battery is 4 or over this may be a cause for concern.
Share this post
Link to post
Doc Hudson
Just for the record LED's can a do deteriorate and fade over time.   https://en.wikipedia.org/wiki/List_of_LED_failure_modes    however re the OP question, I would just be concerned if all other aspects of the alarm itself are functioning correctly. Especially when was the main battery last replaced? possibly a PSU struggling to operate the system and charge a near flat battery. Does the system still function with the mains off?
Share this post
Link to post
Evans Electric
I fitted it in 2004 , done  a couple of panel battery changes ....I'm thinking the LEDs have deteriorated  TBH  ,  I'll call in  & make sure the system works .  Maybe change the bell .
Share this post
Link to post
Richard-the-ninth
Change it to one with no LED's :slap never be a problem again.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Manufacturers
Electrical & Tool Suppliers
Electrical Software
Green & Renewables
Label Supplies
Accounting Software
Education & Training
Motoring
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
