DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
SLIPSHOD & SLAPDASH
Would you mention this
SLIPSHOD & SLAPDASH
Found this  whilst doing a EICR. Not the lack of markings but its connected up back to front. There did not seem to be any markings saying feed & load.20171010_091737.thumb.jpg.6fd03549df3a0990c1877d4f47909508.jpg
Share this post
Link to post
kerching
Well, it's different!
why on Earth connect the fuse before the isolator?
seems a bit weird...maybe a new EU Reg.
Share this post
Link to post
Lurch
Technically nothing wrong as such, but it isn'r right and is at odds with good workmanship so I'd mention it. Maybe even just some relevant labelling would cover it?
Share this post
Link to post
Andy™
so its a fuseswitch and not switchfuse
Share this post
Link to post
ProDave
Deleted, I was wrong.
Edited by ProDave
Share this post
Link to post
Lurch
1 minute ago, ProDave said:
that switch fuse is on the OUTPUT of the meter so the switch is first.
For the neutral yes, follow the live though...
Share this post
Link to post
Rob.
Nothing against the regs in doing that.
I can't make out the rating of the switch, is the fuse protecting it?
IMO no code, what would you code it against? Other than 'that's not the way I'd do it'.
P.s. I wouldn't do it like that either without a good reason.
Share this post
Link to post
Blue Duck
Discrimination?
Share this post
Link to post
Tony S
It goes against convention and someone could get bitten by it. Personally I’d alter it to the more conventional form.
Share this post
Link to post
SLIPSHOD & SLAPDASH
I have not had any luck trying to find the instruction leaflet for this unit. Its a Wylex   110M  which has been superseeded, anyone got a link  ?
Share this post
Link to post
Evans Electric
My eyes were playing tricks  following those strangely coloured , blue meter tails , specially where they cross behind the others .   I thought the polarity was wrong but its not.
However I'm  looking at it as ....incoming Live to possibly 80A  fuse ..then to a DP   switch to isolate the sub- main.
He's  discriminated ( probably) by fitting a separate  fuse from the Service fuse....he's fitted an isolator to the sub-main  .... it does the job ....move on.
Share this post
Link to post
Adrian
No different from the dno service head through fuse then double pole isolater.
Share this post
Link to post
Andy™
completely different. you expect the DNO fuse / terminals to be live at all times. you should also not be touching it either. with a switch fuse, its reasonable to expect the fuse / terminals to be dead when its switched off. at least in this case its a plug in fuse. imagine if it was something with a bolted in fuse. have fun changing that live
Edited by Andy™
Share this post
Link to post
apprentice87
What is that connecting the fuse to the switch?? Looks like a bent up bit of metal rod to me???
john..
Share this post
Link to post
ProDave
john..
I believe it's an enamel covered copper link.  I have seen that in CU's for the links between main switch and rcd. Never thought much of it as it can't take much to puncture the very thin enamel insulation.
Share this post
Link to post
Andy™
john..
looks normal, some CU manufacturers use a solid copper bar bent to shape with very little insulation
never really liked the idea. its a solid round bar, the actual surface contact area at the terminals will be much smaller than if it was a bit of copper thats a bit softer and takes shape better. but still, they cause less fires than 5DW's
Share this post
Link to post
kerching
I have a couple of 110Ms in the garage awaiting to be ebayed
ill see if there are any MIs in the box
Share this post
Link to post
Phoenix
That would be sufficent in my book to be able to quote 134.1.1 as a reg it is non-compliant against. "Good workmanship by competent persons or persons under their supervision....." even if its not specifically against the manufacturer's instructions, its opposite to the accepted custom and practice in the industry and therefore would not be considered "Good workmanship"
Share this post
Link to post
phil d
It was obviously wired by someone who didn't know what they were doing, the incoming live and neutral should have been connected to the bottom of the switch, this was a common thing with certain Wylex units iirc, whoever fitted it probably thought it should be fed from the top.
To be honest, I've seen this type of thing once or twice before, I even saw one on a small one way unit where the live feed went into the fuse, and the neutral feed went to the rail, the load was connected to the terminals of the switch.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Manufacturers
Electrical & Tool Suppliers
Electrical Software
Green & Renewables
Label Supplies
Accounting Software
Education & Training
Motoring
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
