ELCD
You still need to provide an earth to all switches and sockets AND the gas pipe.
An RCD is for additional protection., not to replace an earth conductor.
Some (class 2) appliances do not need an earth, they will be supplied with a 2 core cable, but other class 1 appliances do need an earth, and could be positively dangerous if no earth was connected.
"No to that. He is very busy and won't be for a few weeks."
So the BG man questions the earthing in your property and you are happy to wait a few weeks before its checked out.
Really?
Really?
Don't have much choice he is the only sparky I trust. Moved to this house 2 years ago has probably been like that for years.
Chances are BG bloke doesn't know what he's on about rather than there being a proper fault. The number of times BG have failed installations because their test gear doesn't cope with earth rods.....I lost count years ago.
Yes... they also like to make work for themselves, they get paid incentives I believe.
Just out of interest @Andrew Scott how old is this device (elcb RCD rcbo rccd)???
This is a category of devices, which are used to protect instruments, circuits and operators, while Earth leakage. Early ELCBs are voltage sensing devices, which are now replaced by current sensing devices (RCD/RCCB). Usually voltage sensing devices are called ELCB and current sensing devices are called RCCB.
Voltage sensing ELCBs were first introduced about sixty years ago. Current sensing ELCBs were first introduced about forty years ago. For many years, the voltage operated ELCB and the differential current operated ELCB were both referred to as ELCBs because it was a simpler name to remember. But the use of a common name for two different devices gave rise to considerable confusion in the electrical industry.[citation needed]
since you only know 'more than 2 years', does that mean you moved in 2 years ago? if so, did you have the wiring tested then? if you did, any problems would have been noted then, although its still possible that something has failed since then
Didn't have it tested as it all looked quite new.
Will phone electrician tomorrow.
his mate from the pub could have changed the board, fitted a few sockets etc, bodged the who thing but never mind, it looks new so it must be fine
dont take this the wrong way, but yet again another person who has no interest in checking the safety of their wiring, and only does something once told something is not right, someones had a shock or something doesnt work. its not as if it can kill at any moment without any warning...
