- Nov 28, 2009
- 14,650
- 810
Attached should be the instructions for a machine I have to insttall
A few snippets
Voltage 220V
Earth leakage 50mA
Basic power requirement 800W
Fuse 16A delayed action surge proof
Permanent 10mm ground cable
Connected directly to distribution board.
The plan was a 16A radial circuit in 2.5mm from the (non RCD) distribution board to a rotary isolator and the machine hard wired into that.
But 10mm earth as well as my 2.5 supply? Bonkers. I can't see a 10mm earth fitting the earth terminal in most rotary isolators unless I go up to 63A
Looks like a load of hogwash written by someone that knows nothing about electrics.
I wonder if it comes with a CE mark?
View attachment SitePreparationManual_sciFLEXARRAYER SX.pdf
A few snippets
Voltage 220V
Earth leakage 50mA
