DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Paul 1982
Fitting PIR security light
Question
Paul 1982
I had an old grubby light fitted to the outside of my house. Not a security light just a normal light. I’m after fitting a new light to it, the light had a bulb holder style bit for wiring the live and neutral into (black neutral white live) no were for earth to go so put earth into terminal block with insulation tape around it. Problem is soon as I’ve put power back on the light isn’t going out or switching of at what I’m assuming is the switch for the light as it’s directly below it on the inside of house, can anyone help please
Share this post
Link to post
50 answers to this question
  • 0
Barx
How many wires / cables are at the fitting, is it just 1 x twin & earth?
Did the old one switch off, or just never work?
Has the inside switch been changed at any point?
Cheers
Share this post
Link to post
  • 0
Paul 1982
Yeah just 1x twin earth
When we moved in it was just not working, maybe build was just burnt out, but fitted new one there and it’s constantly on.
Theres a new chrome single switch fitted pretty close by which I though it was maybe being powered from but opened it up just there and the cable that’s being wired into light isn’t to be seen behind switch.
So confused
Share this post
Link to post
  • 0
Paul 1982
Inside of old light and new one fitted
Share this post
Link to post
  • 0
Sharpend
Are there any other external lights along same wall of property that this one maybe linked too? It maybe that the switch is elsewhere if there are.
Share this post
Link to post
  • 0
Paul 1982
When I turn the breaker of marked (downstairs lights) it goes out. Just can’t figure out where’s going and why it’s not going of
Share this post
Link to post
  • 0
Barx
Hmmm, ok. Did you say you have had the switch off the wall? what does that  look like inside (Disclaimer, don't die or even attempt if your not confident. Advise turning power off first).
Does switching the switch do nothing, anywhere in the house?
It could be that the swithch is for the light, but connected wrong.
Share this post
Link to post
  • 0
Paul 1982
There’s a security spot light above it on same wall which is wired to a fused switch but that is switched of ?
Share this post
Link to post
  • 0
Paul 1982
This is inside of switch but the cable that’s wired into outside light is white black and earth which isn’t inside here
Share this post
Link to post
  • 0
Murdoch
You need some test kit, some paper and a pencil IMHO
Share this post
Link to post
  • 0
Richard-the-ninth
It may also be that the switch for the light is infact a scarlet fish, and that the light that was there had either a PIR or a photocell built in and so does not need to be switched off.
Share this post
Link to post
  • 0
Paul 1982
Thanks for all help, I’ve now traced the cable , its going to the single switch in my kitchen, although the single switch doesn’t seem to switch it on of. Maybe wired wrong? Should there be a double switch, one to control outside whilst the other controls the kitchen light?
Share this post
Link to post
  • 0
Paul 1982
Hey guys, I have a fuse box in my garage, a breaker on it powers a constant light on the outside of my garage. Can I remove the old lamp and replace it with a pir security light. So when nothing’s there it’s of but once movement happens it lights?
Cheers
Share this post
Link to post
  • 0
Sharpend
Hold on a minute Paul, this outside light that you originally spoke of- is that the same as the one outside the garage you speak of?
what does the switch in the kitchen switch? Kitchen light?
Share this post
Link to post
  • 0
Paul 1982
Hi sorry I didn’t realise I’d continued a different topic on this other topic. I was meant to create a new topic. No it’s a different light on garage running straight to fuse box, would a PIR work on that cable running direct to my fuse box?
Yeah in the kitchen I have a double dimmer switch controlling both ceiling lights on other side of kitchen I have a switch that puts one of the kitchen lights on and off, this is the switch that outside light is wired to and is constantly on wether switch is on or of ?
There’s about 4 cables roughly in this switch
I’m not bothered at all with it being able to control one kitchen light as I can use dimmer for this. I’d like the switch even to just be used for outside light only, is this possible cheers
Share this post
Link to post
  • 0
Sharpend
Ok so first things first, the garage, you can change the garage light for a security pir light, be sure to isolate supply first.
Now on this kitchen switch have you a photo of it or is it the earlier photo? If
Share this post
Link to post
  • 0
Paul 1982
Great thanks.
Yes it’s the pic from earlier on, I can try get more tommorow if you need more details of back of switch etc?
Share this post
Link to post
  • 0
Sharpend
Do your kitchen lights work ok when switching?
Share this post
Link to post
  • 0
Paul 1982
Yes double dimmer switch works fine
And the single switch that outside light is wire to works fine to kill one ceiling light
Not sure why single switch would only kill one ceiling light and not both
Share this post
Link to post
  • 0
Sharpend
When you say the outside light is wired too, have you confirmed that? If so what terminal does this wire go into?
Share this post
Link to post
  • 0
Paul 1982
Yes I have confirmed that
I’ll need to properly make sure I have the correct cable out of the 4 tommorow and I can say exactly were there going to on the switch.
does it sound like a normal situation , 4 cables going into that switch, well 3 then the 4th going to outside light
Share this post
Link to post
  • 0
Paul 1982
By the looks of it, Lives going into L1 and Neutral to N
Share this post
Link to post
  • 0
Paul 1982
Any ideas anyone if there’s anything I need to swap around in the switch for the switch to work the outside light on and of? :signthankspin:
Share this post
Link to post
  • 0
Barx
For a start, if that switch does the kitchen iight too, then surely you will need to change it to a 2 gang switch?
Share this post
Link to post
  • 0
Sharpend
It does appear to be a single Gang switch, perhaps why the outside light has constant power.
Share this post
Link to post
  • 0
Paul 1982
It is a single gang switch, so I should switch to a double then? Sorry I’m obviously not as clued up as the person that fitted the switch in the first place.
Can I adjust the wiring in the single gang for it to only work outside light as not to bothered on it working the kitchen light that it does just now.
If not have you any tips on how the two gang should be wired up when installed
cheers again for the help
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Test Equipment Manufacturers
Electrical & Tool Suppliers
Tool Manufacturers
Electrical Software
Green & Renewables
Label Supplies
Education & Training
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
