DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
Sign in to follow this
electrics_new
steam generator
electrics_new
I am looking at installing a steam generator for a bathroom - domestic property and single phase.
The manufactures instructions indicate the following:
Use only copper wire rated 600V~ and 75°C or better
All models require Earth connection
All models require Mains plus Neutral connections
All Mains must supply minimum 195V~ while steamer is heating
The steam generator is only 4.5kw so i've installed a 4MM twin and earth radial circuit.
They want the wire to be rated to 600v - even on a single phase supply ?????
Any input would be appreciated......
Thanks in advance
Share this post
Link to post
Sharpend
From where is this generator?
Share this post
Link to post
electrics_new
generator is from helo
Share this post
Link to post
Doc Hudson
4 minutes ago, Sharpend said:
Ooh I have one of those in the garage, now do I remove shower from holder and put the head of this on its place 🤔🤔🙄
If you search YouTube there will no doubt be an American bloke somewhere who has done a very similar thing. Search a bit more!
Share this post
Link to post
kerching
What does it say on the cable?
Share this post
Link to post
binky
I would ignore the 600V bit, I think most cable is arted for this anyway, SWA certainly is, other wise our 500V testing voltage may cause damage. Check Doncaster cables website.
Share this post
Link to post
Andy™
H07 flexes are rated 750
Share this post
Link to post
Tony S
300/600V T+E has been standard for the past 30 years before that it was 600/1000V.  The rating is 300V between  L&N to earth and 600V between L&N.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
FORUM SPONSORS
Electrical Test Equipment
Test Meter Calibration
Test Equipment Manufacturers
Electrical & Tool Suppliers
Tool Manufacturers
Electrical Software
Green & Renewables
Label Supplies
Education & Training
To Advertise and become a Forum Sponsor of
talk.electricianforum.co.uk, please
contact the Administrator
Here Thank You.
