- Joined
- Dec 25, 2011
- Messages
- 5,464
- Reaction score
- 71
I've been offered a couple of old Allen Bradley Integrated Display PCs that'll otherwise be scrapped to have a play with. The place is big on "up cycling" and if it can be made use of rather than binned they're happy for it to go to a good home. Both out of the gennie room. Seemingly both died because they were "running off an inverter" is the story. The "why" is lost in the midst of time. Not opened either of them up yet. Heavy beasts for panel mounting but might make a basic desktop pc for the garage etc with a couple of simple legs or frame!
First, the older and bulkier of the two is a VersaView 1700P a 6181P-17TPXPH. Touch screen, RS232, Centronics, VGA, USB, DVD etc. Powering it up and psu fires up and psu fan runs though noisy. A green light on inside. No screen action. Connecting a VGA monitor and nothing on that.
Second ones a bit newer, again a 1700P, a 6191P 17TPXP so assuming an evolution of the first. Running XP Pro For Embedded Systems, again RS232, Centronics, DVD, USB ports on it (as well as a DVI port), HDD is SATA and accessible externally. Touchscreen as well. Applying power and a get a series of beeps 1/3/4/3. I'm assuming a psu problem. but there's again a green light showing thru the vents. Screen is dead.
Anyone got a link to fault codes etc for these?
LOTS of screws to get inside so other than a cursory glance and plug in it'll have to wait until home on the bench.
Thinking maybe a Linux install of some sort just for a play maybe using the touchscreen.
Cheers
Cheers
