Wooden Bending Block - how to?
dmxrr
Jan 26, 2016
22
U.K.
Hi all,
Currently bored at work and have been trying to make an old-school conduit bending block from wood. I have a block of oak about 10cm x 5 cm x 1.2m, is it just a case of drilling a 20mm hole in it? I experimented with a hole on a 30 degree angle but the bend was poor and kinked slightly.
Cheers,
Ben
I used one at my first job as apprentice  , size I think was as yours but  I think it was about 7cm thick  (3")  .
The sides of the hole MUST support the sides of your bend , like a Hilmore  wheel but it was more oval in height .
The hole was straight through with a chamfer facing you .
90deg bends  were not too good , mostly used a those awful inspection bends  ( This was industry)  but the bending block was mainly used for double sets .     You needed to bend the tube in small increments .
After 3 years I moved from industry to contracting  and found the wonders of the Hilmore pipe bender .
Whats the next project  ?  Fixings with a Rawlplug   jumper bit .?      Resurrecting the wind up Megger ?
Using tallow to lubricate conduit threading  and cooling Enox Cutter Blades ?         Threading your own nipples  and cutting round edge locknuts from 3/4" couplers ?
I made mine from a piece of 4x3. I used a 22mm drill in the radial arm drill. Initially drill though the short side at 90° then twist the wood upwards with the drill still running to about 30°. This will give a Vee shape to the hole and a curve where the two holes intersect.
Thats what I have in the box with my stocks and dies.... when I last needed some (don't do it very often) ordered a pot of cutting compound with the lengths of tube, thats what turned up... was a little supprised as I never thought that it would still be what they kept on the shelf.
Prepped come short sections of conduit for a small job once in my garage... couldn't work out why the dog was so interested in what I was doing :slap
I've seen how tallow is made, its not a nice process
I never liked the smell of it TBH  .   Bought myself  a tin of the stuff pipe fitters use  about 20 yrs ago , still half full in the garage  .  ( Or half empty of course)
Tallow...as an apprentice I remember being sent to the corner shop to buy LARD when the tallow ran out. It reeked.
Now I use Trefolex, RTD, Temaxol. Got a can of squirty pink stuff too I can't remembef the name of, got it off of a pipe fitter.
Thats the stuff  M8.
And working at Cadbury's once , we found when running out of tallow that a hazelnut whirl,  scraped across the thread,  did just as good a job .
Just pick one off the line ...eat as many as you want there ..but never ...never ...stick one in your pocket .
