Angelay
Installation of Hive thermostat
Angelay
Any help would be appreciated, I’ve replaced the receiver from the existing thermostat , the back plate was the same as the hive back plate. Switched on fine , paired ok with green lights but for some reason heating does not fire up.  Any ideas what could be the issue.
Share this post
Link to post
Rob_the_rich
Hi Angelay, probably one, or possibly more, of the wires is in the wrong place. What is the make and model of your old wireless thermostat?
Share this post
Link to post
Barx
A picture of back plate and boiler make / model will help things along.
Share this post
Link to post
Andy™
just because the backplate is the same doesnt mean the wiring terminals are the same. did you read the diagram for the old one and compare it with the new to make sure they were wired the same?
Share this post
Link to post
Angelay
Hi its a centaurplus C27 by Horstmann
Share this post
Link to post
Rob_the_rich
I would guess that one of the black wires is going to the old room thermostat, which is turned down. You can test this by connecting the hive to the back plate, turn heating on with hive then turn up the old stat and see if heating comes on. We would have to see how the old stat fires the boiler before advising how to disconnect it, but at least you would have ch working.
Share this post
Link to post
Angelay
Hi Rob,
there is is no room thermostat, which I why I’m going to the hive to try and give the boiler a rest as once it goes on it doesn’t stop until the time in it switches off.
Ive put the program thermostat old one back on and boiler works fine.
Some where there here must be an issue with these wires I did awhile back put the tado thermostat and that worked fine.
Thks
Share this post
Link to post
Andy™
you still havent answered my question. did you read the diagram for the old one and compare it with the new to make sure they were wired the same?
Share this post
Link to post
Rob_the_rich
Ah ok, where do the two cables which are in the backplate go to? please post pics of boiler, cylinder cupboard pipework and wiring centre if possible.
And make sure you have switched everything off before removing covers. Preferably also the main switch in the fuseboard.
Share this post
Link to post
Andy™
no point taking photo's of boiler etc, if the OP would bother to do what i said the problem will be obvious.
hint, hive doesnt use 3&4... (at least not on the diagrams ive looked at)
Edited by Andy™
Share this post
Link to post
Angelay
Hi I did but thought keeping the old plate would work bit confused on connections 1 and 2
Share this post
Link to post
Rob_the_rich
Andy™
diagram i found shows 1 as common switching to 2&3
Share this post
Link to post
Rob_the_rich
ok pics of back of old programmer and of hive wiring instructions please
Share this post
Link to post
Andy™
well you are right about the old programmer, but since we dont know what new one the OP has and we have both found different diagrams... (the link you have has 2, one of which should be a direct swap, the one i found only had the single channel one with different wiring)
Share this post
Link to post
Angelay
Sorry it won’t let me upload any images of the diagrams, I seemed to have maxed out my upload capacity!
Share this post
Link to post
Rob_the_rich
upload to somewhere like dropbox, then post the link here
Share this post
Link to post
Angelay
Manage to resolve the issue by move 3 to 1 and that worked!
Share this post
Link to post
Barx
Out of curiosity, is it a dual channel hive you have or a single?
Share this post
Link to post
Angelay
I have a single channel as I have a combi boiler
Share this post
Link to post
Sun Direct Heater
It is vital that you ask your expert HVAC tech to make the programmable thermostat works just as well with both the heat and air units as there are some that work better with AC units than they do with heat pumps causing problems during winter. On the other hand, temperature settings and thermostats only make up a part of the picture as far as heating and cooling a home or business efficiently. You should also think about weather stripping your home to keep cool air from escaping in the summer and warm air from escaping in the winter.
The skilled specialists will be able to assist you with the large variety of programmable thermostats with improving the efficiency of your HIVE system. Furthermost homeowners set their thermostat to one temperature and certainly not change it. When you install a Smart Thermostat, you can set your temperature at dissimilar times during the day and the thermostat programs itself to learn your temperature preferences. This saves you time as you don't have to concern about altering the heat ever again.
Share this post
Link to post
kerching
I would have hope that the OP had sorted this by now as they asked the question almost 3 years ago
just saying
Share this post
Link to post
Bruspark
Will the movie start after the adverts ?
Share this post
Link to post
kerching
It has been an 'intermission break' since day one as far as I can see...
never actually gets to the Main Feature which , having looked at the grammar , may require sub titles
Edited by kerching
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
