Hi, I have some mold problems and am looking for a cheap solution to keep air moving more and reduce moisture in the air for a flat I rent out.
I was wondering if I can simply have a timed switch fitted to the bathroom so that it would run on maybe 20 mins after it was switched on ?
or is there a better answer ?
ideally I think it would be better to have a humidistat fan or constantly running at a low level, then faster when the light is on ?
I currently have a vent axia via 100 lt directly above the shower .
thanks in advance
thanks in advance
