New Energy saving device
They have been about for years, oh, and did you notice what is wrong with the "plug"
Did you notice in the T&C's it has a 3month warranty?   7.1. Company warrants to Customer that, for a period of 3 months following the date of shipment to Customer (the "Warranty Period") any hardware portion of the Product will be free of material defects in material and workmanship.    Also, from point 9.  shall be governed exclusively by the laws of Thailand.   Its got to be good then eh?  Its a shame the applications don't include schools, hospitals, police/fire/or ambulance stations, or public buildings in general. As I guess our council and the NHS could have saved loads to reduce the council Tax or parking charges at our hospital. Never mind
Power factor plays no part in kWHr metering. It does if you’re billed in kVAr.
Yet more snake oil from the Indian sub continent.
Baahhh, Humbug, your just spoiling the expectations of the gullible few. You are supposed to be positive and encouraging on a Friday night, with a weekend to look forward to. Couldn't you save those sort of comments till Monday or Tuesday?
Doc H
Sorry did I miss the technical specs :C
I also note their confidence,
every second German Family has one....... ny now ???
FFS! I do not wish to be negative but the old phrase shouldagonetospecsavers maybe?
Technical specifications
Suitable for your standard electrical wiring at home, comes with UK plugs
Use multiple energy saving units all over the house to maximize savings
Dimensions: 12 cm x 7 cm x 4 cm
Weight: 170 g with packaging, 125 g without packaging
Maximum humidity: 85% (not allowed to be installed in bathrooms)
What is the problem Sharpend? Or have you had the odd one, two, or more tipples tonight?
In fact, from those specifications I think Deke could work out the Volume in cubic cm. AND the weight of the packaging. How often do you get both of those?
Power factor correction - something I looked into a few years ago, a very technical subject that can offer big rewards when designed specifically for an installation, so any universal piece of kit is unlikely to work effectively, as discovered by Plymouth University, who decided to fit universal PF correction units and were disappointed with the results!
This is from another "power saving" site.
Power Saver stores the electricity inside of it using a system of capacitors and they release it in a smoother way to normal without the spikes. The systems also automatically remove carbon from the circuit which also encourages a smoother electrical flow. This means that we will have less power spikes. More of the electricity flowing around circuit can be used to power appliances than before.
WARRANTIES AND DISCLAIMERS
This site and the Materials and products on this site are provided "as is" and without warranties of any kind, whether express or implied. To the fullest extent permissible pursuant to applicable law, Power Factor Saver disclaims all warranties, express or implied, including, but not limited to, implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. Power Factor Saver does not represent or warrant that the functions contained in the site will be uninterrupted or error-free, that the defects will be corrected, or that this site or the server that makes the site available are free of viruses or other harmful components. Power Factor Saver does not make any warrantees or representations regarding the use of the Materials in this site in terms of their correctness, accuracy, adequacy, usefulness, timeliness, reliability or otherwise. Some states do not permit limitations or exclusions on warranties, so the above limitations may not apply to you.
LIMITATION OF LIABILITY
In no event shall Power Factor Saver be liable for any damages whatsoever, including but not limited to, indirect, special, incidental or consequential damages, whether in an action of contract, negligence or other tortious action resulting from use of, or the inability to use, this site or arising out of the use or performance of the Materials available on this site, regardless of whether Power Factor Saver or an authorised Power Factor Saver representative has been advised of the possibility of such damages. In the event that, notwithstanding the foregoing, Power Factor Saver is found liable to any user of the products for damages from any cause whatsoever, and regardless of the form of the action (whether in contract, tort (including negligence), product liability or otherwise), the maximum aggregate liability of Power Factor Saver to you arising in connection with these terms and conditions shall be limited to the amount paid for the products in the twelve (12) months prior to the accrual of the applicable claim.
