DONT STAY LURKING AS A GUEST,
CLICK HERE TO JOIN.
  • 0
Clueless-noob
CCFL, neon or something else?
Question
Clueless-noob
Hello community, I’m not an electrician and I’ve no one else to turn to so I’m hoping the mighty power of the internet can lend a hand.
Can anybody out there identify this bulb?
It’s approximately 60cm long is very bright but doesn’t get hot. Could it be a type of neon? Or maybe a CCFL, although I’ve never come across one like this before?
135B785D-FAE4-4E0C-BBE2-91ADE7A0EA17_zps
Share this post
Link to post
13 answers to this question
  • 0
Sharpend
What is it out off?
Share this post
Link to post
  • 0
Clueless-noob
I’m not sure but it was used to make a ‘neon lightsaber’ prop ...although how accurate calling it a “neon” is I’m not too sure. There’s doesn’t seem to be an electrode on the ends which makes me think it has to be something else
Share this post
Link to post
  • 0
binky
looks like a PL type lamp,  which is flourescent technology, although I have never seen one that size and shape
Share this post
Link to post
  • 0
Richard-the-ninth
Only a guess. Cold cathode?
Share this post
Link to post
  • 0
Clueless-noob
Ahh ok, that’s interesting. I don’t know anything about PL type lamps - I’ll have to do some research
Share this post
Link to post
  • 0
Clueless-noob
My guess at first was a cold cathode, admittedly I don’t know much about them but I’ve never seen any like this one - The ones I’ve seen are for in computer housings and for under cars. They have a wire running on the outside connecting both ends where as the one in the picture is a “U” shape (of sorts)
Share this post
Link to post
  • 0
Geoff1946
What voltage does it operate from, and is there/was there associated control gear?  My first guess was that it was from a photocopier but that is just a guess.
Share this post
Link to post
  • 0
Ardet R
There does not appear to be a phosphor coating so fluorescent is out unless the phosphor is very worn.
I cannot tell if there is a wire inside the tube, in which case it could be an incandescent.
Without a wire or phosphor coating it would have to be a neon or discharge lamp, but then that comes back to was there any control gear with it, the type of which would be a dead giveaway.
Share this post
Link to post
  • 0
Clueless-noob
It connects to a transformer (unfortunately i don’t have with me to see the details of) which then plus into the wall socket.
It did light up green, not sure if that’s any help.
Share this post
Link to post
  • 0
Clueless-noob
I honestly don’t know about a/ the control gear (which is probably really not helping things). It used to light up green and didn’t used to heat up so It’s sounding more and more like a neon tube i think, but i was under the impression that a neon would need an electrode on each end to work?
And all the CCFL tubes I’ve seen on google tend to not be “U” shapes.
Share this post
Link to post
  • 0
Andy™
looks neon to me. if it was fluorescent it would be UV-A due to the lack of coating
Share this post
Link to post
  • 0
Evans Electric
Never seen anything like it either ,  if its green then I'm thinking neon .    Just enlarged the photo , can't see an element .
I think Geoff is close with the photocopier theory.
There is something similar in Heidelberg  printing presses  only much bigger and costing  the equivalent of various human  limbs  .
Share this post
Link to post
  • 0
Marvo
If it's neon then the transformer will often be made from a heavy ceramic/porcelain material because of the very high voltages involved, I'd also expect the wires at the end of the tube to be heavily insulated. With neon, there would also most likely be stickers all over it warning you about the high liklihood of death if you touch anything and I also doubt it would be sold with a standard plug on it if it were neon. It looks like a quartz tube to me so my first guess would be an OEM sterilizer lamp or sunbed in which case it will be UV-C which is also dangerous, if it is UV then a lamp that size will cause permanent damage to your eyes in a short space of time.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
