Mastbruch
Calculator confusion
Mastbruch
Morning fellas.
I just wondered whether or not anyone could point me in the correct direction on when calculating capacitive reactance which buttons to press on the calculator, I’ve found the Pi button and used the 10 to negative etc etc but for the life of me the answers are no way correct coming out.
Thanks.
Share this post
Link to post
Sharpend
Please put up the formula you are using.
Share this post
Link to post
Mastbruch
Apologies.
C=0.05 uf.          f=100khz
I just can seem to find how to put the power 10 negative in my casio 85gt plus calculator.
The answer is apparently 32 ohms but for the last 4 hrs I’ve had no luck coming to that answer.
Edited by Mastbruch
Share this post
Link to post
Sharpend
Which calculator?
Share this post
Link to post
Mastbruch
Casio 85gt plus
Share this post
Link to post
Sharpend
I think you’ll find that you have to put (negative value) then push the (10x) button the multiply by farad value.
Share this post
Link to post
Mastbruch
Still no Joy. What ever I’m typing in on the calculator it’s not coming up with the answer 32 ohms.
Share this post
Link to post
bluetobits
Any good?
Share this post
Link to post
Ardet R
Sequential operations to carry out
"0.05"
"x"
"6"
"10^x"
"x"
"100000"
"x"
"π"
"x"
"2"
"M+"
"1"
"MR"
31.83
Edited by Ardet R
code did not work
Share this post
Link to post
Tony S
Try using Excel.
Share this post
Link to post
Mastbruch
Thank you very much gentlemen much appreciated.
Share this post
Link to post
Mastbruch
On 14/03/2018 at 16:35, bluetobits said:
Any good?
I think I must be going nuts I still can’t find the power of 10 negative on my calculator tried everything from YouTube, all sorts, I thought I’d done it but hadn’t.
My old calculator had an E and the one before had a EXP where you’d press that an automatically the 10- would come up but this is really stating to get my nerves big time.
ive tried everway possible to stick 10 to negative 6 in my calculator by punishing in the sum above and not got anywhere near 31.83.
so it’s defianlty 1 divided 2 to start with. I’m getting the answer 7.85 every time
Edited by Mastbruch
Share this post
Link to post
Sharpend
The lot below the divide line you can either work out separately then hit the 1/x button or do the bottom line within brackets after hitting 1 / buttons.
Have you not followed Ardet’s post?
Share this post
Link to post
Mastbruch
Unfortunately I couldn’t make head or tail of of Ardets numbers mate TBH I slung them in the calculator and all sorts were coming through.
The funny thing is when I’m calculating resistivity using the 10 to negative it works fine and the answer I want comes in.
Got a feeling this calculator won’t be working in a short while.
Share this post
Link to post
bluetobits
Don't know if this little snippet from the instructions is of any help to you.
If not you could always convert to farads yourself as in the example. Hope you get it sorted
Share this post
Link to post
Sharpend
Enter the following:
0.05 multiplied
Then type (6 then hit the plus/minus key)
then hit 10 to power of button,
what do you get?
Share this post
Link to post
Mastbruch
0.05 multiplied
what do you get?
It comes up syntax error, what makes it 100 times worse is I was doing it all the while when I first got the calculator and for the life of me not sure where I’ve gone wrong.
Edited by Mastbruch
Share this post
Link to post
Rob.
type  0.05
Press the shift button, then press log,
That will give you the 10 to the power of x. x will be in the display as blank. So type in - 6
Also, you've got it set to math mode haven't you. Should say in the top right corner.
Share this post
Link to post
Mastbruch
1 hour ago, Rob. said:
type  0.05
At the very top I have a little m then in the middle a little square then the top right a triangle
Share this post
Link to post
Mastbruch
FINALLY DONE IT HORRAY. Thanks for the help fellas.
Share this post
Link to post
Sharpend
So how?
Share this post
Link to post
Mastbruch
I restored the calculator back to factory settings.  In my time of despair I must have changed all the settings on it because the button I originally thought changed the 10 now works.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
